How Do I Stop That Beeping Noise
/ How Do I Stop That Beeping Noise #1
kcender
Nova Scotia
GR2120 B2650 Cab
I recently bought an L45 and discovered it has a back up beeper as standard equipment.I live in the country but there are neighbors near who may become annoyed listening to the beeper,I probably would.The beeper is a safety feature but I don't feel it is necessary for my situation,I won't be using it on a construction site.The noise is coming from a box under the left floor near the rear tire.The box is a sealed unit with a large electrical plug.Unplugging the plug prevents the tractor from starting.I don't see a fuse for the beeper or a switch near the foot pedal.It seems Kubota has made it hard to unhook the beeper.Has anyone ever disabled the back up beeper on an L45,or any other Kubota that has one.I am pretty sure the M59 has the same setup.
/ How Do I Stop That Beeping Noise #3
Unplug it and put small jumper wires in the plug. If it is a female plug.
Put duct tape over the speaker
The speaker is inside the sealed box,which looks like it may be a computer so I am not willing to play with it.
The plug has about twenty wires,I didn't count them,so I need to know which one is for the beeper.As I said,I think the box may be computer so I really don't want to damage it, which could get expensive.
/ How Do I Stop That Beeping Noise #6
. Look for the sensor that tells it it is in reverse.
/ How Do I Stop That Beeping Noise #7
The buzzer is listed in the L45 parts on Kubota.com parts. If the thing is not expensive, you could order another one and gut it. Or get a better understanding of the set up. I wonder if your local dealer would have one in stock that you could look at.
The last three tractors that I was assigned to had backup beepers on them. Hated the sorry things. You could break one wire and it would not function again. But yours is set up different.
/ How Do I Stop That Beeping Noise #8
Your dealer may be able to show you a pin out diagram for the connector. That would tell you what wire to cut.
/ How Do I Stop That Beeping Noise #9
If it was sealed, you could not hear it. Can you post a picture?
Backup beepers are usually mounted at the back, I put a piece of foam rubber over mine, can't hear it in the cab, or 1/4 mile away. But anyone close enough to be run over can hear it. :thumbsup:
It certainly seems to be coming from inside the box.The box is hard plastic on five sides with a shiny black rubber coating on the back.The sound is able to be heard no problem.I will get a picture of it later.
Mystery solved.There is a beeper/speaker but I wasn't able to see it before.It is just beyond the black box which is why I thought the noise was coming from the box.I unplugged and removed the beeper.Everything seems to work fine and what a relief it is to not have to listen to that beeper.I filled the electrical plug with dielectric grease to keep it from rusting.Thanks for the help and suggestions.
/ How Do I Stop That Beeping Noise #12
:thumbsup:
/ How Do I Stop That Beeping Noise #13
This information could prove more valuable than the discovery of the Rosetta Stone.
/ How Do I Stop That Beeping Noise #14
thanks for the info now i can sneak out late at night for some alone time with my l45, and my neighbor wont come running asking for help because he can hear me moving about
/ How Do I Stop That Beeping Noise #15
Well we all learned something today.:thumbsup:
2021 John Deere 4044M (A64126)
2021 John Deere...
UNUSED ATS POWER ATS-MIG-140 MIG WELDING MACHINE (A64281)
UNUSED ATS POWER...
2020 GMC AT4 CREW CAB TRUCK (A60430)
2020 GMC AT4 CREW...
2013 Chevrolet Traverse SUV (A61574)
2013 Chevrolet...
2022 BOBCAT T870 SKID STEER (A64279)
2022 BOBCAT T870...
UNUSED WOLVERINE RSB72-72" ROCK SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
