How do you store you logging/tow chain?
   / How do you store you logging/tow chain? #261
Very professionally done.
   / How do you store you logging/tow chain? #262
Very professionally done!
   / How do you store you logging/tow chain? #263
Well today I built my chain holder. Two 4" square tubes 18" long welded together. I think they were 14ga. I welded a cap across the bottom and drilled 5 holes in each side for drainage. I am pleased with it. The front tube has a 20' 5/16" chain and is full and the back tube has two 5/16" chains about 8-10' long and is also full. I mounted them on to the side of my loader with six small welds.
What I wanna know is why is your John Deere painted orange ? :D
(Nice job BTW)
   / How do you store you logging/tow chain? #264
Thanks, I'll take that as a compliment, it's another one of my add-ons, I use that hitch all the time, it has a spring loaded pin to lock in straight back or in a folded position to temporarily keep it out of the way so I wont bang my knee in it. When I'm not using the hitch, I pull the pin in the receiver and store it on the loader mount. I looked all over the net for a fold away trailer hitch and couldn't find any.
Fold Away Bolt-On Trailer Coupler Hinge Kit - Google Search
   / How do you store you logging/tow chain? #265
Thanks for the input, (Fulton - Fold-Away Bolt-On Hinge Kits) That is what I found a few years ago, primarily made for boat trailers. I don't think those would work for me, my folding trailer hitch swings to both sides for easier hook-ups, has a spring loaded self locking pin so if the trailer is hooked on at a 45 degree angel, when tractor moves forward, the hitch swings to a straight position and locks, then on real heavy loads, I put in a second case hard 1/2" bolt to hold the hitch straight, also the hitch can swing back at 90 degrees and locks when not in use, also I can reach around back and pull a pin to remove the hitch and mount it on my loader mount till I need it again. I'll have to get some better pics of it.
   / How do you store you logging/tow chain? #266
On floor brd on tranny hump of my L4310, on front ballist weights of the L245
   / How do you store you logging/tow chain? #267
My criteria for good chain storage are:
1] Low on tractor - ~ CG or below
2] Midpoint to rearward because of loader
3] No width added at any point
4] Not in space closely affected by front wheel&axle articulation
5] No change in ground clearance or addition of anything of a soft nature to the undercarriage
6] Convenient access and stowage.
,,,The best and simplest place Iv found so far is knotted and hooked into/onto the floor platform on the 7520. With work, another good/better one would be a container fastened to the top of the righthand step. Another one, more work, would be a rugged graft onto the lower rail of the backhoe subframe.
   / How do you store you logging/tow chain? #268
,,,The best and simplest place Iv found so far is knotted and hooked into/onto the floor platform on the 7520. With work, another good/better one would be a container fastened to the top of the righthand step restricted to the inner part of its profile. Another one, more work, would be a rugged graft onto the lower rail of the backhoe subframe.
   / How do you store you logging/tow chain? #269
You can always hit them a lick with an orange rattle can once in a while.:)
I don't have an orange tractor, but I have been buying more stuff with bright colors. New hunting knife last year was orange. Utility knives lime green.
Blasting the hooks with orange would be nice. But I don't see it lasting to long.
Great thread, lots of great ideas. Some simple ones I haven't thought of before. How to carry tools has been on my mind. I am in the woods a lot, and I don't see a carry all or ballast box, being the way to go. End up smashed pretty quick. Though for working on projects it would be good
   / How do you store you logging/tow chain? #270
I painted my chains orange makes a big difference in finding them after I lay them down. When paint wears off just hit them again.
BUYERS PREMIUM & PAYMENT TERMS (A52141)
BUYERS PREMIUM &...
2013 Ford E-250 Cargo Van (A50323)
2013 Ford E-250...
2024 INGERSOLL RAND IRD25 HYD TRACK DUMPER (A51243)
2024 INGERSOLL...
1816 (A50323)
1816 (A50323)
2020 HINO 195 CAB AND CHASSIS (A51222)
2020 HINO 195 CAB...
Online Buyers Premium (A47384)
Online Buyers...
