54C belly mower - blades not overlapping?
   / 54C belly mower - blades not overlapping? #1
nfernandez
Byron Center, MI
John Deere 2210
I just purchased new blades for my 2210 with a 54C belly mower. This is the first time I replaced the blades (only owned it for a year) and when I got the new ones, I noticed they didn't overlap at all. I found the part number from JD Parts and actually noticed they are identical to the ones that were on there. So my question is, why do these blades not overlap? If they aren't overlapping, won't they leave streaks? Below is the part number I was told to order from the John Deere site. Any input would be great. Thanks!
B1PD5026 Predator2 Mower Blade for 54-inch John Deere Deck - B1PD5026
   / 54C belly mower - blades not overlapping? #2
The spindles are staggered so the cutting path (footprint) does overlap.
Can you explain that more? I don't think I understand what that means. Thanks!
   / 54C belly mower - blades not overlapping? #4
Each blade has its own cutting path. The center blade is forward and the path made by the two other blades overlaps that of the forward center blade.
   / 54C belly mower - blades not overlapping? #5
the blades arent suppose to overlap.. the center blade (spindle) is near the front while the left and right blades are near the rear - this allows you to get the coverage you need for cutting and not risk having the blades hit each other
   / 54C belly mower - blades not overlapping? #6
This is larger than your belly mower, but it shows what beenthere and thatguy were explaining.
   / 54C belly mower - blades not overlapping? #7
If they did overlap like you think they should, then eventually, due to belt slippage, they would be hitting each other and then you would be posting about the severe noise and vibration you have!!!:D
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
2016 Dodge Journey SUV (A56859)
2016 Dodge Journey...
SDLD25 MINI DUMPER (A58216)
2015 Infiniti QX60 SUV (A56859)
2015 Infiniti QX60...
Skid Steer 59in Vibratory Roller (New/Unused) (A59225)
Skid Steer 59in...
LOT OF I-BEAM (A58374)
