Dealer Need to buy a new engine for our power trac pt422
   / Need to buy a new engine for our power trac pt422 #1
djshadowz8801
Current engine is subaru robin engine eh65 22hp, valves are screwed up and we cannot get the machine ready, gaping them is being a *****, no power to the hydraulics, the machine is ten years old and is need of an overhaul, any engines in the 22 hp or 25 hp that would be compatible with the pt422 system?
   / Need to buy a new engine for our power trac pt422 #3
Here's another place to check: Engines
   / Need to buy a new engine for our power trac pt422 #4
did you take the head off and are the valves burned? total hours on machine/engine?
Robins are primo engines, but just pretty rare. I actually have an oem Subaru single cylinder EFI engine powering my Kubota UTV.
two of my favorite places to check out small engines:
Home - Small Engine Warehouse
TulsaEngineWarehouse.com - Replacement Engines, Parts, Tools & Accessories For Briggs & Stratton, Honda, Kawasaki, Kohler & Tecumseh
the questions are usually whether the engine mounts are compatible, the shaft the right size, length and keying, and does the exhaust system clear, among others.
I think you would be better dropping in a replacement engine like David suggested. Considering how valuable your PT is, that cost for the replacement engine seems like a fair investment.
Neither Subaru or Honda builds/markets here small twins over 20-23hp. That market is all Kohler, Briggs and Kawasaki.
Most of us would try to add a hp or two when replacing, if we could, but if you aren't using your machine for full power applications constantly, even dropping a hp or two might work.
funny, I posted the same link as above at the same time...
even funnier is eating my words/hat by studying the link; yes Subaru does market up to 40hp here. that's new.
I checked the dimensions and shaft size; looks like you could go up to 28hp based on similar shafts and similar physical dimensions.
   / Need to buy a new engine for our power trac pt422 #6
I would recommend logging in to the Power-Trac forum and post your needs.
http://www.tractorbynet.com/forums/power-trac/
   / Need to buy a new engine for our power trac pt422 #8
Your best bet is an exact replacement if you want to avoid having to do modifications. As a last resort, call Terry at Power Trac and ask him how much they'd charge you for an engine.
   / Need to buy a new engine for our power trac pt422 #10
The Predator looks like a Vanguard clone, but will its pressurized lube work as well on PT grade slopes?
My friends who have used Lifan and other Chonda motors have been totally pleased.
I have no idea of clearances available but if doing a lot of mowing, a canister style air filter would be a nice upgrade.
Those nice plastic engine covers look good, but Briggs, for example, had some early problems I read with dirt infiltration past the seals on the air filters. What works flawlessly on a log splitter might not work out in the fields...
Hopefully one gets what one pays for.
Massey Ferguson 1745 Hesston series (A53317)
Massey Ferguson...
2009 Dodge Ram 3500 Flatbed Truck with Liftgate (A55973)
2009 Dodge Ram...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A56435)
2025 Mahindra 6075...
Hilti TE 2000-AVR Electric Jack Hammer (A55973)
Hilti TE 2000-AVR...
2018 Nissan Pathfinder SUV (A56859)
2018 Nissan...
