Rotary Cutter Need a new PTO shaft for an old Hardee rotary cutter
   / Need a new PTO shaft for an old Hardee rotary cutter #1
ml8163
Franklinton, NC
Fordson Dexta, Massey Ferguson 2615
I have an old 6ft Hardee rotary cutter that I need a new PTO shaft for. Had this cutter hooked to an old tractor for many years. Just bought a new tractor and the PTO shaft wont go on the PTO. Looks like over time the spkines have twisted. It is a Hardee model number T 166 LT. Does anyone know where I can buy this part?
   / Need a new PTO shaft for an old Hardee rotary cutter #2
Can you not buy replacement pto shafts at Tractor supply?
Or does it have to be a Hardee specific shaft?
I've never bought a PTO shaft so I don't know if I need a Hardee specific shaft or not. I will check around some of the local agr-equipment stores though.
Thanks for the help!
   / Need a new PTO shaft for an old Hardee rotary cutter #4
IF not specific to Hardee, then they are just a generic pto shaft.
good luck
   / Need a new PTO shaft for an old Hardee rotary cutter #5
You might just need a new "end" on the shaft, probably a U-joint yoke. I would not think it to be too expensive to have done at a shop that repairs PTO shafts, if you don't want to try to change-out the yoke yourself. Make sure the rest of the shaft is "good" before replacing parts of it.
A new shaft might have safety guards your old shaft does not have- something to think about. And maybe a slip clutch instead of a shear pin, which you might want??
A photo or two of the cutter end of the PTO shaft, and of the input shaft of the cutter, would probably get you more suggestions.
The U-joint yoke is exactly what I need, but failed to put into words. And yes... I think a new shaft could have some safety guard challenges. That is why I was asking about the particular model.
I just got off the phone with Hardee and got the new spline yoke ordered for $59.92 plus shipping!
Thanks for everyone's help!
jet ski trailer (A56859)
jet ski trailer...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56436)
PENDING SELLER...
2006 Cummins DGBB 35kW Standby Diesel Generator (A56857)
2006 Cummins DGBB...
INBOARD DRIVE (A58374)
2023 Kubota Z252KH-54 Zero Turn Mower (A56435)
2023 Kubota...
(APPROX. 640BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 640BF)...
