moldboard plowing 6530
/ moldboard plowing 6530 #21
Oh no I haven't. I moved a little (7 foot wide full bucket) clay the other day and had one rear tire up about a foot into the air before I knew it. I was turning and backing, so I slammed the bucket down and all was forgiven.
hugs, Brandi
If tractors don't dance a little you are not working them hard enough!
/ moldboard plowing 6530 #22
I wasn't trying to work it. I was just moving one (only 1) bucket of dirt on a Sunday afternoon. Check my threads out. I can make the Big RED Beast dance when I want to.
Brandi
My new tractor was delivered and I was able to use it this weekend. I didn't do any plowing but I did quite a bit of disking with an 8' tandem disk and the only time you knew it was back there was when I was going up hill. After really looking this tractor over I'm impressed with the quality and how user friendly the machine is.
RMOMN
I have a 5530 Turbo 4wd and I pull 3x16's @ 8" deep. No weights except a 266ML loader with the bucket for plowing. My plow is Ford/Dearborn 10-209 with coulters. A 6530 should have no problems with 3 16's.
View attachment 422516View attachment 422517RMOMN,View attachment 422518
idaho2
Idaho2, How did you get your plow to go 8" deep. I have adjusted my 3 pt arms all the way down and I get 6-7" and when I lift the plow all the way up it is only 4" above the ground. It is like there is not enough range of movement. I'm guessing that since I have the 3pt all the way down my draft control will not be able to go any lower?
40ft 10 Door Shipping Container (A64194)
40ft 10 Door...
2008 MACK GRANITE KILL TRUCK AND TRAILER (A65643)
2008 MACK GRANITE...
2004 GMC Sierra 2500HD (A66408)
2004 GMC Sierra...
Kubota SVL 75-2 Skid Steer (A65579)
Kubota SVL 75-2...
John Deere 350B Crawler Dozer (A65579)
John Deere 350B...
Interstate 20ft Tilt-Deck T/A Flatbed Equipment Trailer (A64553)
Interstate 20ft...
