Hinomoto E2302 Service Manual/Parts manual
/ Hinomoto E2302 Service Manual/Parts manual #1
Ouray
SOUTHWEST FLORIDA
HINOMOTO E2302 DIESEL 26HP
Recently Purchased a Hinomoto E2302 3cyl 26 horse Diesel Tractor. Need some help locating Service Manual/ Parts Manual. I also understand there may be a Massey Ferguson model that parts may interchange with? Does anyone know what that model would be?
Thanks, Ouray
/ Hinomoto E2302 Service Manual/Parts manual #2
I can supply you with manuals.
/ Hinomoto E2302 Service Manual/Parts manual #3
The 2302 is a very close match to the MF1030 and the Deutz Allis 5220. There are some differences between the tractors though. I have had a few 2304's and my dad had a DA5220 and the Hinomotos were actually nicer and had more bells and whistles.
I appreciate the information...You are right the Hinomoto seems to be a good one so far...Has plenty of power but I seem to be having traction problems in the sandy soil in our area?Thanks for your Help
ouray
/ Hinomoto E2302 Service Manual/Parts manual #6
I had traction problems also until I filled the rear tires with anti-freeze.
Eugene
Re: Anti-Freeze in rear tires
Thanks for the Tip! I'm new to tractor world....Do you have to have special equipment to fill the tires this way?Or is it a matter of putting the valve stem on top and removing the valve core and forcing the anti-freeze in that way?Don't Laugh now!
/ Hinomoto E2302 Service Manual/Parts manual #8
The problem is always getting the air out while putting the liquid in. I think NAPA sells a little adapter that allows the air to come out while filling with a garden hose.
/ Hinomoto E2302 Service Manual/Parts manual #9
I have seen a dealer take the tire off, lay it down, break the bead on the top side and pour it in and then reseal the bead with air pressure.
Eugene
Thanks, Greg I'll Check out the NAPA store!
Thanks Eugene, I'll talk to the local Tire shop!
/ Hinomoto E2302 Service Manual/Parts manual #12
Does this adapter have a siphon feed to fill with antifreeze too or is this pure water? I've been looking for way to add antifreeze or a solution of calcium chloride to mine but all i've found is to fill with water only..at tsc
/ Hinomoto E2302 Service Manual/Parts manual #13
Mix the solution in a 5 gallon bucket, get a washing machine hose and buy a small electric pump from Sears, Harbor Freight of hardware store. The hose has 2 female ends(1 for the fitting and 1 for the pump). Put a short piece of hose on the other end of the pump and put the remaining end in the bucket. The pump is self priming.
Eugene
/ Hinomoto E2302 Service Manual/Parts manual #14
I am also in need of the E2302 manuals. Thanks for any help you can give me!
2014 GMC Yukon SUV (A61574)
2014 GMC Yukon SUV...
2021 Kubota SVL 97-2 (A62177)
2021 Kubota SVL...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
2012 PROCO 130BBL VAC TRAILER (A63569)
2012 PROCO 130BBL...
NEW HOLLAND C227 SKID STEER (A64279)
NEW HOLLAND C227...
