The starter fluid tire trick works!
   / The starter fluid tire trick works! #11
I've done it a few times but it scares the snit out of me every time. Watched two guys try to reseat a 44" bogger on a mud truck about 10 years ago, one of them ended up in the hospital with burns to his face and neck. Lucky he didnt lose his eyes. Be careful.
I have done it more times than I care to remember on truck and tractor tires. I will never forget late one night in the shop mounting a new set of 44 on 16" bar wheels.
When they pop on, they dang near had 30 psi in them
   / The starter fluid tire trick works! #12
After she blows, the air coming out of the valve stem can be quite toasty.
   / The starter fluid tire trick works! #13
I am too chicken to try that! Scared to death of fires and explosions!
Will
   / The starter fluid tire trick works! #14
   / The starter fluid tire trick works! #15
It's funny that you did that today, I was just up getting my riding lawn mower ready and one of its tires was flat and off the rim from sitting all winter. First thing I did was go looking for some starting fluid, but it is all still stashed away in the bacement to keep from freezing in the winter. So I tried to used the ratchet strap trick but there was too much deformation from sitting all winter. I ended up getting it to seat by packing grease in the rim on the bad spot while using the ratchet strap.
   / The starter fluid tire trick works! #16
I cheat ,I have an old coats 10/10 tire machine with a bead blaster . I have done the starter fluid back in the day with 44's on a cj7 jeep . It was a experience
   / The starter fluid tire trick works! #17
I wasted an entire evening one time going through YouTube watching videos of seating beads this way. Some were perfect. The worst I remember is blowing the entire front end off a guy's pickup. Reminded me of Butch Cassidy and the Sundance Kid when Paul Newman blew up a safe and the money flew over an acre. "Think you used enough dynamite there, Butch?"
   / The starter fluid tire trick works! #18
I've witnessed this several times 4 wheeling. It's very entertaining to see a bunch of red neck guys gathered around each offering advice but only one brave enough to be "the guy". :)
   / The starter fluid tire trick works! #19
Heheheheheh. I've lost track of the number of times I've used that line to describe a large variety of experiences. :D
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2015 FREIGHTLINER...
2021 CATERPILLAR D3 CRAWLER DOZER (A52709)
2021 CATERPILLAR...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A56436)
Case Wheels for...
2001 Dorsey 48ft Flatbed T/A Trailer (A56858)
2001 Dorsey 48ft...
