CK20 Hi Lo shifter stuck with Four Wheel Drive shifter
   / CK20 Hi Lo shifter stuck with Four Wheel Drive shifter #1
jmonte0330
Warwick, NY
Kioti Hst 320 JD X340
It seems like my Hi Lo shift is stuck together with my 4 wheel drive shift. When I put the Hi Lo shift in the HI position the 4wd shifter goes into 4wd; when i put the Hi Lo shifter in LO position, the 4wd shifter goes into 2wd?
Also, will not go into Hi range
Could they be stuck together for some reason?
Thanks in advance for help.
   / CK20 Hi Lo shifter stuck with Four Wheel Drive shifter #2
Are the levers side by side with the shaft of one lever going through the hollow shaft of the other. If they are then they could be seized together. You should be able to loosen the two of them up by spraying with WD-40 or equivalent and working the shaft's against each other. You might have to do that for some time or just take them apart and clean them up.
The Hi Lo shifter is on the fender and the 4wd selector is below your left leg when seated. I will try to lube them
Thanks.
   / CK20 Hi Lo shifter stuck with Four Wheel Drive shifter #4
They must have some linkage in common if they are moving simultaneously. Check under the tractor. I'm just guessing but is it where they enter the transmission?
   / CK20 Hi Lo shifter stuck with Four Wheel Drive shifter #5
Don't think the levers have a common linkage. If I remember correctly, on my CK35H the range shift goes in the side, the 4WD lever goes in the front of the transmission. Sounds like it might be an internal issue.
   / CK20 Hi Lo shifter stuck with Four Wheel Drive shifter #6
Experienced same situation.
Lubricate linkage under fender with penetrating oil (I used PB PowerBlaster) and operate Hi - Low Range back and forth until linkage frees up.
Club Car Carryall Electric Utility Cart (A55853)
Club Car Carryall...
2007 KENWORTH W900B (A58214)
2007 KENWORTH...
40' High Cube Multi-Door Container (A57149)
40' High Cube...
(2) METAL & WOOD STORAGE RACKS (A52708)
(2) METAL & WOOD...
20ft x 30ft Steel Carport (New/Unused) (A59225)
20ft x 30ft Steel...
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
