Cost per bale
/ Cost per bale #1
powerscol
SW Colorado
CT 235
Just got done computing this years cost per bale - $6.08.:eek: I had a lot of material and equipment repair costs to refurbish the older equipment - learning I should have bought newer. I did not include my near new equipment as it was a 719 write off against my other income and taxes owed. I produced 920 bales this year, and lost 72 of those to rain damage, along with 42 that I did not get paid for.
My guess is next year I should be closer to my $3 mark that others have said they are at.
What are others producing standard hay bales at.
/ Cost per bale #2
Nobody does the math or they would be buying. Did you figure in the cost of land?
/ Cost per bale
No on the land cost as I hay a lot of fields owned by others for free. I cut so they don't need to mow 3 acres.
If I did it would be out of this world. I do it for fun as I am retired.
Just like riding my horse, when I am on the tractor working, the world can pass me by as I am happy, and to me that's priceless.
/ Cost per bale #4
I had this discussion awhile back on a similiar thread and I may not have the same numbers but here goes. Remember I'm from KY and it may not relate to your area an I'm using round, average figures. Lets say grass/legume hay in 1000lb round bales. 75% grass, 25% legume. Production of 3-5 tons per acre annually. To cut, ted, rake, and bale. Equipment purchase, repair, fuel, oil, grease, depreciation, insurance, $15 per bale. Fertilizer, very variable, 300lbs of 19-19-19 per acre or a 57-57-57 at $500 a ton lets close to $10 per bale(again I'm using round or average #s) Add a $1 a bale for annual overseeding, another $1 for lime. Pencil in your own numbers if you rent or own the ground. Other factors include labor, time, herbicides, hay market in your area, etc. I'm only familiar with my area, not yours. Your figures/situaton may be vastly differant and I'm not trying to encourage you one way or another. I make and buy hay. Sometimes grass in a bale is not hay, it's not much more than bedding.
/ Cost per bale
So if I add your numbers up for your 1000 lb bales your at a min of $27 a bale. I run the small squares at 55 lbs each so I would have about 18 bales to your 1. Rounding up for extra time and materials to produce the small square that would put me at roughly $2 a bale or a bit less using your costs. As I am just starting out, given the learning curve and now having rebuilt equipment to run, I am hoping my $3 costs holds - at least for planning purposes.
Am I thinking correctly, or am I out of my head :confused::eek::D
Hay around here is $6 to $8 on the small squares ($12 at feed store for grass/alfalfa ) or between $80 and $150 for large squares (920 lbs to 1300 lbs)- this is for good quality horse hay. Cow hay is at the bottom end of those numbers $2 to $4 for 2 string.
/ Cost per bale #6
I think you are on track with your numbers. But I know nothing of raising hay in Colorado or the hay market there. Can you produce 3-5 tons annually? What profit margin are you expecting? Do you need to pencil in trucks/trailers for delivery? Buildings for storage?
/ Cost per bale #8
Can someone explain this comment for an old guy?
It is from a young guy, he just joined today and this post got deleted by a Moderator.
Rekt means get drunk: https://www.google.com/url?sa=t&rct..._xNBPGzl1mddGx_iRtT7YSg&bvm=bv.89947451,d.cGU
Here is his other weird post about an internet game site: http://www.tractorbynet.com/forums/rural-living/334547-evan-bergster-bergo-lets-get.html#post4099525
/ Cost per bale
I was wondering, especially the $your mom.......just what we need here too.....NOT!!!!!!!!!!
Hopefully the Mod can set the young man straight. Hopefully he can learn something.
On edit - looks like the other post was removed too.
Thanks Moderator - appreciate the help.
/ Cost per bale #10
Powerscol, Your cost per bale will continue to go down as you get your equipment into shape, and hopefully get down to the $3 per bale that you hear others doing.
You are probably headed to the same conclusion as most when it comes to haying small parcels-- you just cannot make it pay. Once you figure your costs, then add in a small amount for your time and trouble, you would have to charge more than the price of just buying hay.
So are there any reasons to continue haying small parcels? You bet there are:
1) The enjoyment of getting out there with your tractor and doing something productive.
2) The quality control that you have with the hay you feed your horses-- you know the quality of the hay better than anybody else if you are the one baling it
3) It is easier to justify upgrades to your equipment and implements-- you are spreading the cost among several fields
4) Exercise
Even if you can't turn a profit, there are still good reasons to do it and I support you going out there and getting the job done.
/ Cost per bale
Thanks. Other than my head exploding every time I fill out the Sch F (lousy line by line instructions and no IRS help) when it comes to the bottom line helping on my tax bill it helps.
And I agree - most important I know what my horses are eating and so do the few customers I have. They see the fields it cam out of and so far are happy.
My biggest lesson learned was in the choice of the equipment. Folks said to start with the older stuff and work out of them. For the funds I have put in to the old stuff I could have bought new, or near new out of rental fleets. I am so glad I got the newer baler.
As for the exercise, yes I need it, but I hope to put the hay grapple to work this year to at least save my back a bit.
To get back on track, what are other folks costs to produce a bale of hay. I know it varies from one part of the country to another, but it would be worth knowing.
/ Cost per bale #12
I hesitate to calculate it but my father says we make about 65c per hour if I don't count his time (he's retired). We do all squares and I figure I'm under $2 per bale with all old equipment, and light to moderate repairs. This year I spent 3k on a tractor upgrade so it will be closer to $3, but last year we had a good year and were about $1.50 per bale with high fuel costs. If your making only a couple thousand bales per year, 1 repair can skew your numbers a lot, and if you bought a 30k modern tractor you can't make those numbers work. All that is not counting labor.
/ Cost per bale
Yep I work cheap too - for the grins:D
Sometimes I think I retired too early, but the stress of working with the new generation of engineers that took no pried in their work was causing health issues. I supervised 57 1/2 employees in the design and construction of public works projects, and between Contractors that could not read and understand the contract they signed and some of my engineers making calls it was close enough (costing us millions down the road) I threw in the towel. I know am in better health and enjoy, just being me. I hay to stay busy.
/ Cost per bale #14
We bale coastal bermuda rounds for ourselves and sell squares to horse owners. First cutting with winter grass goes into rounds for the cows. After that its all square bales. The 2nd, 3rd, & 4th cuttings are highly fertilized to get the right protein content. Lots of expensive herbicides. 1500# round bales have about $25 - $30 in them, squares have $2.50 plus $1.00 in field and stacking labor. Years that we irrigate the cost of a square can get up to $4.00, but the irrigation pump can burn 50 gallons of diesel a day. This year we sold squares for $7.50 out of the barn, $6.50 in the field. There are about 25 squares in a #1500 round bale so a round bale has $190 of square hay in it. That's why we never sell rounds unless its really sorry hay that only a goat would eat, like the year it rained for 3 straight weeks right after we cut. Some years we have even bought rounds for the cows and still sold our squares.
/ Cost per bale #15
We do around a thousand small squares each year. One cutting. Seasons are short up here and the latter part of summer can be cool and wet. I have baled 2 cuttings but only a couple of years out of the past 8.
Wife and I are both retired now. Got into this to get good hay for our horses. But, it's also good old fashioned work, that we both enjoy.
Just our input costs - fuel, herbicide, twine, grease, seed, fertilizer - works out to about $5/bale. 20-10-10-8sulfer is $825/ton this year; FOB Soldotna, AK.
Good, quality horse hay is around $12/bale for a 50lb bale. Twenty bucks for the same hay in the local feed stores.
I don't factor in the purchase cost of my equipment as the re-sale of well maintained quality machinery up here is darn near what you bought it for! As I have upgraded through time, the sale of my older equipment has enabled us to step up to the newer implement.
AKfish
/ Cost per bale #16
you guys are way over thinking owning your own hay equipment.the fact is most of yall here have small places you bale for hay.that means 1 thing its hard to get a custom baler todo the job.even if you could find 1 with a small square baler.plus your at the mercy of the custom baler.who may not get to your hay on time.
/ Cost per bale
338 - pardon my thoughts here,but your missing the point. I am a small custom baler, just starting out, going into my second year and trying to be a sponge on the steep learning curve. I am retired with a good retirement income, so the hay business is to keep me busy and active, and is actually somewhat fun.....Stacking by hand does S....! After doing my Sch F for the year and backing the cost out per bale, I was surprised. It was more than my business plan had estimated, but I did not count on the number of repairs that I had to do to the older equipment. I started the thread to find out what others were experiencing to see if I needed to change my plans any.
I got into baling for your exact reasons - the custom baler quite the area. I have small equipment, so I am trying to fill the gap, and get hay for my horses and feed a few select costumers needs. Goal is to reduce my property taxes, and possible break even or make enough to take my fantastic boss unit out to dinner. After reviewing my costs I was doing a gut check with others here to find out what their costs were running compared to mine.
Now if I can find a cheap way to ship to Alaska, I am all in. Years ago I thought of moving there, until I figured out the real costs, and the fact that as I get more wiser in years the more I know I am getting more allergic to snow.
Thanks for your input though
Keith
/ Cost per bale #18
It's interesting to read this thread. I don't know anything about haying and don't intend to start. On the other hand I do buy 10-15 bales of wheat straw for gardening and for the fall "Hay" rides. Sometimes even straw is hard to find and runs 7-10 $ per bale...I guess you'd call it two string bales.
Cheers,
Mike
/ Cost per bale #19
About 5 years ago, when the drought was at its worst here, my total summer hay crop was 26 rolls (4x5) from 52 acres. Figuring lime and fertilizer, twine and normal maintenance costs, I think it was around $400 per roll!!! :eek:
/ Cost per bale #20
Heard that! That was the year we resorted to baling milo stubble. I don't know how many acres we had to rake, but we made about 300 4x5 milo stalk bales. If you haven't ever cut, raked, and baled on top of row crop hills... Its an experience!
CT
Genesis Rescue Tools with Power Unit (A64553)
Genesis Rescue...
2017 Ford Fusion SE Sedan (A64557)
2017 Ford Fusion...
2019 East Manufacturing 48ft. T/A Walking Floor Trailer (A64556)
2019 East...
2022 JOHN DEERE 350G LC EXCAVATOR (A65053)
2022 JOHN DEERE...
2020 Ram 1500 Pickup Truck (A64194)
2020 Ram 1500...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
