Mahindra 3525 hydraulic system problem (suction filter?)
   / Mahindra 3525 hydraulic system problem (suction filter?) #1
ZX12R
high springs florida
mahindra 3525
Hello all. Newb here. Signed up out of necessity and the need for knowledgeable help.
I lost hydraulics today digging up an old stump. I've been thumbing through my manual with little to no success. Fluid level is okay. In the troubleshooting section, it points to either the pump (I'm hoping it's not that) or a clogged suction filter. I don't know what that is or where it's located, in order to check that first. I also don't know what it looks like.
Can anyone help me locate it.
P.S. I'm assuming it's not the main hydraulic oil filter. (190 hrs on tractor)
   / Mahindra 3525 hydraulic system problem (suction filter?) #2
Look for parts online and you should be able to find it -here is a link to a parts place with 3535
Error
You tube may also help
   / Mahindra 3525 hydraulic system problem (suction filter?) #3
Unlikely to be either. ... Does your 3point hitch work? Do you have remotes?
larry
larry
Rear hitch? I didn't try it. It was up and I left it alone so I could drive it to the house. I will go and try that in a bit. Remotes? I don't know. What are remotes? I didn't really mention that I lost all function of the front loader.
Sorry I'm so ignorant about this.
Just checked the rear hitch. Doesn't lift at all. It seems like I have zero pressure to all cylinders.
   / Mahindra 3525 hydraulic system problem (suction filter?) #8
So, does your front loader work?
If no hyd, check your sump filter if you have one. Look in the manual for location.
Check that the hyd pump is actually turning.
Check that you have fluid at the pump IN port.
A hyd gauge should help you troubleshoot your hyd system.
   / Mahindra 3525 hydraulic system problem (suction filter?) #9
OK. Im guessing there are a lot of connections at your loader valve/joystick. Put your bucket on the ground, tractor off. Disconnect each Quick Coupler by pulling back the collar, and then reconnect it. After youve done all the QCs start up and see if it works now. They get out of wack sometimes if something hits them.
Remotes are sources of pressurized hyd fluid that you can plug an implement into. Sometimes the valve that controls them will be inadvertently put in a position that affects the other parts of the system. Look for remotes and their control valve. Put this valve in the center position.
larry
Nope, nothing works.
The only filter I can find is the main Hyd. filter. It is mounted near the sump but above it. Looks like a normal car oil filter.
I have two of the hoses disconnected from the pump. I'll start it and try to look in and see if I can tell.
At this point, other than the pump, the only thing I can think it might be is the valve that handles the overpressure, is stuck open, but I have no idea where it is.
I think I'm just going to pull the pump. Maybe I sheared something on the drive gear. The hyd. failed quickly while I had the bucket stalled under tremendous
force trying to pop out the stump.
2012 UTILITY VS2DX 53FT DRY VAN TRAILER (A52141)
2012 UTILITY VS2DX...
Gator (A50324)
Gator (A50324)
Kubota RTV-X900 Utility Cart (A50322)
Kubota RTV-X900...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A52128)
2018 John Deere...
2016 MACK GU713 GRANITE DUMP TRUCK (A51222)
2016 MACK GU713...
