Extendable lower link arms?
/ Extendable lower link arms? #1
Dieselrider
Central PA
1979 John Deer 2640, Kubota L3800
Has anyone ever seen, either from Kubota or plans for DIY, extendable lower link arms for the 3pt hitch on a Kubota L3800? Being a compact with less room between wheels and such, this thing is much harder to connect and disconnect 3 point hitch implements to that my JD2640 that does have the extendable lower link arms. Just wondered if any one has ever run into this and what your solutions were. Thanks
/ Extendable lower link arms? #2
My solution was a weld-on Pat's Quick Connect.
Cut off the balls and weld on a Pat's. Done. (And I did it to a tractor with the extendable arms - M7040.)
Of course, you could use the regular bolt-on Pat's but the geometry changes a bit since the lower arms are effectively longer.
/ Extendable lower link arms? #3
Kubota sells telescopic stabilizers for the L series, but I have not seen telescopic ends. However, they sell them as options on other models, and it's possible they would fit. Might want to see if units from a Grand L would fit on an L.
/ Extendable lower link arms? #4
I also used the Pat's weld on for mine and my dad's. Got a piece of 2&1/2 by 1/2 flat bar and four new ball ends from ag supply and made new lift arms with rigid stabilizers. L3700 & L3800.
/ Extendable lower link arms? #5
I've got them on my Grand L4330. They don't side too well and the bulky sheet metal release handle interferes with my Woods Brush Bull frame. I'd look into a quick hitch of some sort instead.
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
PEMBERTON 9' STACKING RACK (A64276)
PEMBERTON 9'...
2014 Freightliner 105' Bucket Truck (A63689)
2014 Freightliner...
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
8' X 16' FARM WAGON (A64276)
8' X 16' FARM...
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
