Fecon Hydraulic drive motor spline
   / Fecon Hydraulic drive motor spline #1
APSmulching
Newton, NJ
Fecon FTX140, Bombardier GT-500-HY, New Holland TC45DA
I started doing some work to my bh85 this weekend and had a hard time removing one of the hydraulic drive motors. It was seized, so I have to remove it with the spindle shaft on it. With some heat and a hammer I got it apart and found that the splines were really worn out. Especially on the one that was seized. So I need to replace the spindle shafts with the female spline and the spline output shaft on the Rexroth motors(1-3/8 - 21 tooth)
Those splines have a lot of stress on them and I have put a thick moly grease on them but when ever I check them after about 500 hours they are dry. Has anyone had any luck using another type of lube there?
   / Fecon Hydraulic drive motor spline #2
Castrol Optimoly Paste White T
It won't completely stop the fretting and corrosion but it will sure slow it down.
I was told that DuPont Krytox may be good for splines also. I want to use something that will help the spline to last longer. Im getting prices for new shafts for the Rexroth motors and my first price is 1600. each. That's a lot more than I expected
   / Fecon Hydraulic drive motor spline #4
APS,
I believe on the Rexroth A2FM bent axis motors that the shaft includes the complete rotating group so that would explain the $1600 each. You may want to ask your parts supplier to confirm this.
   / Fecon Hydraulic drive motor spline #5
Hi, I'm the Service Manager for FECON for future tech support or service needs please call 800-528-3113. We use anti-seize to prevent corrosion on the two spline shafts. This should solve your issue,
Thanks,
Hi, I'm the Service Manager for FECON for future tech support or service needs please call 800-528-3113. We use anti-seize to prevent corrosion on the two spline shafts. This should solve your issue, Thanks,
Thanks Skidplate, what kind of anti-seize do you recommend? They make a lot of different types now. The new Fecon shafts with the female spline look like they have a little copper anti-seize on the splines.
   / Fecon Hydraulic drive motor spline #7
That's it the copper base anti-seize. A light coat on the male and female splines.
   / Fecon Hydraulic drive motor spline #8
You can buy the female spline end as a replacement part, cut the old one off and weld the new one on. Much cheaper than buying a new shaft unless you want a spare. When you replace the shaft on the motor the rotating group and bearings have to be replaced as well so you end up with a fully reconed motor at about half the price of a new one. Its been suggested to me that I drill a hole through the spindle shaft and fit a grease zerk in the bolt hole where the pulley sits and give it a pump of grease every so often. Got to better than pulling motors off especially when you're busy.
Hey Tony, I knew you would chime in. You have been through it all. I thought about reworking the spindle shafts with a new female spline but called and found out they were not that expensive. He also mentioned the new shafts are one piece now and not welded.
I also talked to an engineer from Loctite and they said that the best way to stop spline wear is to bond them together with cylindrical lock, like #680. You just won't be able to pull a motor without the shaft coming with it. I just did it with the one that was seized so it's not too bad of a job. With a little heat the loctite will soften up to remove it. To replace the motor splines with parts and labor is coming in at almost 2000.00 each.
   / Fecon Hydraulic drive motor spline #10
The last shaft I purchased was AU$1100, the billet end was AU$85 plus fitting so for me it's worthwhile as long as the shaft is ok where the bearings run. A good bloke with a lathe and welder can knock the job over in a couple of hours.
2012 MACK CHU613 (A50854)
2012 MACK CHU613...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A51222)
2003 FONTAINE...
2011 Ford F-450 Crew Cab Omaha Service Truck (A50323)
2011 Ford F-450...
3-Point Bale Spike and Kroyker Loader Combo - Includes Trailer Hitch Adapter (A51039)
3-Point Bale Spike...
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
