Hydraulic pump
/ Hydraulic pump #1
triangel
melville sk canada
new holland t1510, 730 case
I need someone to translate what is on this pump. I am planning to use this on a wood processor I am building and I would like to see if I can use this pump on it. easter with the boys 066.jpg
/ Hydraulic pump #2
Fordermenge = the output = 5.55 cubic cm/revolution = .33868 cubic inches/revolution. Max. Drehzahl = 2500 rpm. Max. Betreibsdruck = working or operating pressure 300 kg/cm2 = (kgf/cm2) = 4267 psi.
/ Hydraulic pump
Thank you for your reply, One more question, how many gallons per min flow at 2000 rpm. would this pump be fast enough for a splitter with a 4" x24 stroke cylinder
/ Hydraulic pump #4
5.55 cm3/revolution = 0.00146615 US gpm or 0.00122083 Imp. gpm. Since most hydraulics are in US gpm I'll go with that. 0.00146615 x 2000 rpm = 2.9323 US gpm. Now this is the part that I'm not sure of. There might be an efficiency factor in here that I'm not aware of. JJ or someone who knows more can correct me.
I do know a bit of German but I wanted to double check so all I did was Google those German words and I had my hunches confirmed. The conversions I did with an app on my phone.
/ Hydraulic pump #5
Here is some data on pump efficiency.
Theoretical flow is calculated by multiplying the pump’s displacement per revolution by its driven speed.
Actual flow has to be measured using a flow meter.
/ Hydraulic pump
Thank you to all who replied, I guess this pump will have a lot of power but will not have any speed for this ram. need about 14-16 gpm.
JLG E300AJ (A60462)
JLG E300AJ (A60462)
Massey Ferguson 4710 (A60462)
Massey Ferguson...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
2020 CATER PILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A65053)
2020 CATER PILLAR...
