TC33D
   / TC33D #1
fancyhorse
Allentown, New Jersey
TC33D New Holland
tractor won't start. Instrument panel 1st light won't light up.??I ordered 3 new glow plugs but don't know where they go. Help. Illustration would be helpful.
   / TC33D #2
You need to be specific on what the tractor is doing. Does it turn over, do the dash lights come on, or nothing at all happens.
Make sure the PTO levers are off, the shift lever is in neutral, and the parking brake is set. There are a bunch of possibilities to go through before I would replace the glow plugs. Those are only a starting aid.
   / TC33D #3
I wonder if the safety switch under the seat is malfunctioning. You can jump them with a piece of wire to test them.
   / TC33D #4
   / TC33D
Larry, thank you for responding. Yes all is as you say, PTO, neutral, 4 wheel drive, parking brake, all is where it should be when trying to start. Yes it turns over when trying to start (new battery last fall). Yes lights go on on dash except for the 1st one (looks like a light bulb).
   / TC33D #6
OK, If there is enough power to roll the engine over then I would start looking past the battery. You glow plug light should light, although a diesel needs to roll fast to fire up.
Make sure the PTO light is not staying light after the first few seconds, that could mean a wire has become detached...been there :) .
The relay powering the glow plugs could be failed but that would just make it hard to start... not stop it from starting.
I had my brake switch move and not make good contact but if I sat in the seat it made no difference.
I would check the seat switch as well. Do you have a meter? If we're going to diagnose this over the interwebz it may take some time, be patient.
And read the thread JDRancher linked to...it covers numerous problems.
   / TC33D
ok will check PTO lite/wire, seat switch, etc. today. Do not have meter. Need to fill container with huge pile of horse manure/shavings today?hope it starts?wish me luck
1998 Volvo VN T/A Dump Truck (A56858)
1998 Volvo VN T/A...
2020 Toro Pro Sweep Vacuum (A55787)
2020 Toro Pro...
JOHN DEERE 624K WHEEL LOADER (A58214)
JOHN DEERE 624K...
2013 John Deere 27D Mini Excavator (A55973)
2013 John Deere...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
