Quick Hitches Kubota BX2751 quick hitch
/ Kubota BX2751 quick hitch #1
Tony891
Oregon,Ohio
BX2660
I have the shorter shaft that goes to a Kubota BX2751 quick hitch. This fits the BX2200 and 2230 tractors for driving a front mount snowblower. I am looking to trade for the longer 14.75 inch shaft that fits the longer framed BX2350 and 60 series tractors. The kit is called a BX2753 and it is over $600.00 from the dealer! You still use the same BX2751 quick hitch but you simply replace the 11 inch dual splined shaft with the 14.75 to compensate for the longer frame. If you bought a used hitch and need the shorter shaft please let me know. Thanks
/ Kubota BX2751 quick hitch #2
I am looking for the shorter spline shaft. Do you still need the longer one?
Dave
Dave
I already bought the longer shaft but I have the short one for sale for $75.00 plus shipping. $80.00 would more than likely get it to you. Thanks
/ Kubota BX2751 quick hitch #4
I would love to buy it. Thats a very fair price. Could you please e mail me your info and method of payment. Thank You.
DDIGGLER@COMCAST.NET
I sold that shaft a while ago. Check on eBay. Thanks
/ Kubota BX2751 quick hitch #7
I have a Bx 2370 tractor with less than 50 hours on it so I am still in the Honeymoon phase!
I have just installed the BX2750D front snow blower and noticed that the shaft in the 'quick hitch' is floating in the two flange bearings. The bearings have holes for 2 set screws each, but the set screws are missing. It seems that the shaft could drift forward and the rear spline would then have dangerously little engagement.
Should this shaft be secured by set screws, and what size are they? 1/4-28 thread seems to fit better than any metric I have tried, but imperial threads in a Kubota?
Would anyone have a parts list for the BX2751 quick hitch? I was also supplied with a BX2753 PTO drive line kit, but no info. I can't see any numbers on the bearings without taking the blower off again, hoping to avoid this, thanks.
Yes you need to make sure those set screws are in place and tight. I am not sure what the thread size is but I did notice they loosen up on my quick hitch too. If the shaft floats and spins it will wear out your bearing raceway retainers. You could use the blue loctite thread sealant.
/ Kubota BX2751 quick hitch #9
Thanks Tony;
I have seen a page from what is a manual for the BX2751 sub frame, I see a lot of inch dimensions, so maybe 1/4-28 is not unusual. I would love to get a pdf of this manual, does anyone have any leads?
Thanks again, Peter
/ Kubota BX2751 quick hitch #11
Thanks Tony;
Yes I see the bearings. The number in the list is: 70060-00925 This must be a Kubota part number.
I talked to the dealer and they said the bearing is imperial, for a 1 inch shaft and there should be 7 -3/8" protruding from the rear and about an inch of non-splined shaft sticking out past the front flange. this position is different from what I have read in this forum, I think. Maybe I'm making to big a deal of this, just don't want to mess up my nice new Tractor
/ Kubota BX2751 quick hitch #12
The parts with the holes for the set screws are actually a lock collar and seperate from the bearings. It looks like there are two holes in each lock collar for two set screws. However, if you look at them closely, only one of the holes actually will be threaded for a set screw. The other hole is a very shallow hole. This hole is so you can "lock" the lock collar onto the bearing. To do this you need to get the lock collar as close to the bearing as you can and then with a punch and a hammer, turn the collar by driving (tapping) it around the shaft. The directions say, and this is a quote from the instruction sheet for the BX2752 PTO kit, "Fasten the shaft by turning the bearing's locking collars in the same direction as the PTO rotation (counter clockwise) and secure the bearings with the setscrews".
Oh, and they do not list the setscrew as a seperate part #. In fact, the bearing and lock collar are one part number. 70060-00925
Also, FYI, the BX2751 is the lift assembly only. It is not the PTO kit. The PTO kit with the long shaft is BX2753 and the PTO kit with the short shaft is the BX2752. This may help you when looking for manuals.
2011 MAGNUM TRAILER LIGHT PLANT (A67714)
2011 MAGNUM...
2016 FREIGHTLINER 125 DAYCAB ROAD TRACTOR (A65054)
2016 FREIGHTLINER...
LAWN MOWERS/WEEDEATER/HEDGER (A67714)
LAWN...
Unused 2021 Unused Paladin MD60SC 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2021 Unused...
2019 INTERNATIONAL DURASTAR 4300 REEFER TRUCK (A67714)
2019 INTERNATIONAL...
2014 Chevrolet Impala Sedan (A66738)
2014 Chevrolet...
