SCOTTYDAWG
I'm looking for a rotary cutter for my DK40 SE hst , some guys have told me a 5' will work better than a 6' in thick grass/brush. This is a new tractor for me any suggestions would be great.
Honestly, any really thick grass and brush will thoroughly defeat a rotary cutter. They tend to simply whomp the stuff rather than cut it.
Well, that pic shows a rather forgiving swath through tall grass. C'mon over to the Eastern Shore an try getting through the Phragmites and salt bush, with a lot of poison ivy thrown in for extra spice!My Woods rotary cutter has NO problem in thick grass or brush at all! It cuts it down and cuts it up,
There's a reason their nik name is "brush hog", as that's what they were designed to do, cut heavy grass and brush...
I do some custom cutting, it's heavy grass and brush that I cut most, it's amazing how tough my Woods cutter has been!!
As for 5' or 6', more power is better in heavy stuff, especially grass...
SR
Honestly, any really thick grass and brush will thoroughly defeat a rotary cutter. They tend to simply whomp the stuff rather than cut it. You will probably have to do several passes if it's truly jungle-like.
I would steer you towards the 5 footer. Way easier to manoever and less weighty. 6 foot is a little much for your tractor.
Have you thought about a chemical approach? You can buy a LOT of glyphosate fot the cost of a rotary cutter.
Grass takes a lot of HP because the duty cycle is very hi ... but seriously, Where are the trees and brush? My BX1500 MMM would handle that grass.My Woods rotary cutter has NO problem in thick grass or brush at all! It cuts it down and cuts it up,
SR
larry
