Kubota storage comparment
/ Kubota storage comparment #1
PAPPASMURF
Gold Member
JACKSONVILLE, AL
2011 KUBOTA L3200 W/ LOADER, BH77 BACKHOE
Made these storage compartments out of 4" PVC for my L3200. They worked out great and I have tools, and misc. stuff in them. What do you think?
:thumbsup::thumbdown::2cents:
/ Kubota storage comparment #2
That looks really neat. How is it closed on the back side? And what holds it in place while you are working?
A 4 inch cap is on the other end. I drilled a 5/16 hole in the protruding portion of the round support bar, and through the wall of the PVC compartment. A coupler pin snaps in the hole which holds the compartment in place. I will try to add some pictures soon. Thanks for the compliment !
/ Kubota storage comparment #4
Looks great I was looking at doing something like this you gave me some nice ideas
/ Kubota storage comparment #5
What a clever idea and well executed... not even much to rust of rattle...
Yep.....and it looks like it was built by the factory! lol Thanks ultrarunner!
/ Kubota storage comparment #9
Awesome idea!! I need to do that!
/ Kubota storage comparment #10
Real nice!!!
What was used at the end to box in the end of slide in and out porcine.
/ Kubota storage comparment #11
Brilliant!
How much of a royalty do I need to send you for utilizing your idea?
/ Kubota storage comparment #12
When I see things like this it shows my lack of creativity. I would never have thought of anything like that. I'm with boblibido.
/ Kubota storage comparment #13
Fantastic job!
I could see making one like this that goes the full length with dividers..
Did you scuff up the PVC before painting? Are you seeing the tube get scratched up as it comes in and out, does it have a lot of friction as it slides?
/ Kubota storage comparment #14
Well Done!!
Great use of an unusual space! I may adopt your PVC idea but affix it to the ROPS (for longer tools). I guess that water could penetrate if it were left outside and it rained. Perhaps you could, "incorporate an O-ring into your ingenious invention". One that would slip over the 4" PVC and would be retained by the cap, A Dremel tool to divot the circumference of the cap to get that snug fit.
I think that you could market this as there are so many loader Manufacturers that utilize this same (empty hole) on their FEL. I would buy one!!
May want to patent it and sell your idea, it is a good one.
Is yours deep enough to hold a chainsaw file? That was the first thing that popped in my head for a use.... that and spare chainsaw chains/rag's.
/ Kubota storage comparment #15
Not only do I like the clever idea of doing this in the loader frame tubes, but think of cases where you could simply strap on a big PVC pipe and then make a smaller PVC pipe drawer that slides in and out. I think the circular cross section would have many advantages on a tractor. Makes a real convenient drawer shape for tractor use.
PAPPASMURF, how did you slice the pipe lengthwise -- table saw?
/ Kubota storage comparment #16
Great idea!
A thought, instead of screws PVC glue could have been used.
Someone suggested using an O-ring, if the ring was about 1/2" in it would create a snug fit and possibly eliminate need for the PIP pin.
/ Kubota storage comparment #17
Those of us who lurk on this site long enough see the wheel re-invented time after time... I like the PVC tube idea- you have good access to whatever you store in it. Paul Short did something similar about 5 years ago by machining some aluminum caps that fit into the loader arm crosstubes. They had O rings to hold them in place, and seal, and a handle to pull them out. But no "tray" for little goodies. I forget what he was storing in there.
Well Done!!
It's exactly 1 foot long, so yes a chainsaw file and extra chain will fit. This tube does not go all the way through to the other side, they are only about 1 foot 2 inches on each side so it worked out perfect. I have a tie down strap (ratchet type), 3 wrenches, two screw drivers, vice grips, chain saw tool and file, and pliers in one compartment!
Band saw with a guide. :)
Great idea!
The caps are glued, and screwed I was just making sure the cap would never pop off! lol :cool2:
2014 CHEVROLET CAPRICE POLICE CAR (A66091)
2014 CHEVROLET...
2017 Ford Escape SUV (A66738)
2017 Ford Escape...
Set of 4 Unused 10-16.5N.H.S. ForeRunner Skid Steer Wheels and Tires (A66734)
Set of 4 Unused...
CAT D9G Rollers (6) (A68134)
CAT D9G Rollers...
2018 CAT D6TXL DOZER (A67714)
2018 CAT D6TXL...
2018 32ft Forest River Lacrosse 3211RK T/A Travel Trailer (A66738)
2018 32ft Forest...
