Firefox freezing up; will not shut down.
   / Firefox freezing up; will not shut down. #32
Same here, I switched flash to be "always ask to run" and Firefox has been happier. As a bonus, videos no longer auto play when I open a new page :D
I have done it in the past. I generally go to Task Manager, open the Processes tab and close the process named plugin-container.exe first. That closes all Firefox plugins (Flash, Java, etc) and will sometimes fix things.
Aaron Z
thats a good bonus
I am running Firefox 36.0.4 on my Windows Vista PC and it has never given me any problems... The only thing I could suggest if all else is failing it to uninstall and reinstall Firefox, although this would mean that you'd lose all your bookmarks and active log-ins.
I did the reinstall, but I did not uninstall the old Firefox, I assumed that the new install would delete the old one. My computer only lists one version of Firefox in my list of programs installed so I hope I am OK.
   / Firefox freezing up; will not shut down. #34
I uninstalled Firefox and then re-downloaded it and I still had all my bookmarks and log-ins.
   / Firefox freezing up; will not shut down. #35
the only time I have a freeze up is when I'm using youtube.
I have a problem with FF not showing prices on For Life Out Here | Tractor Supply Co. . Does anyone else?
None of the other browsers I've tried, give me any issues. I went to FF and Waterfox years ago because others were flawed, especially IE, but it seems the tables have turned.
   / Firefox freezing up; will not shut down. #36
I see prices on there with Firefox. Try clearing the cache and the cookies for that site (https://support.mozilla.org/en-US/kb/delete-cookies-remove-info-websites-stored)
Aaron Z
   / Firefox freezing up; will not shut down. #37
i've done that several times, and again just now...no luck.
   / Firefox freezing up; will not shut down. #38
I'm not have any problems seeing the prices at TSC either. Are you using the most current version (36.0.4) of Firefox?
   / Firefox freezing up; will not shut down. #39
Yup, its been that way for the past cuppla versions.
2013 John Deere 35D Mini Excavator (A55973)
2013 John Deere...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2014 International Maxxforce DT (A53317)
2014 International...
ST225/75R15 Trailer Tires (A55788)
ST225/75R15...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A55315)
Michelin CARGOXBIB...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
