Failed bearing 7010
/ Failed bearing 7010 #1
Keltic
Cape Breton Island
13 LS 7010C,91 Kubota L4150,Thomas 153S< Can Car C-4,BobCat 35E, BobCat 590,Pete 378 Tandem, Lots of other junk.
Had a bearing in the front hub fail, anyone experience this? Only 500 hrs.
/ Failed bearing 7010 #2
Full of fluid? Did it get moisture in and freeze? I say you posted it was -20C recently in your neck of the woods!
CT
No, full of oil and it failed while the machine was moving some snow, just started making noise and puked all the oil out on the ground.
/ Failed bearing 7010 #4
Sounds like catastrophic failure. If your tractor is still under warranty, I'd be calling the dealer! May be more than a bearing failure at this point.
CT
Oh it was, and I must give my dealer, ( Pattersons, in Moncton NB ) kudos for their quick response, replaced the entire hub as an unit and I'm back in business, Thanks to Pattersons and to Earl's in North Sydney NS, for doing the work. I hope it was strange one-off. Tractor is gently used.
/ Failed bearing 7010 #6
Modify Snow Pusher.jpgI have a 2012 LS7010 that I purchased at Patterson's in Moncton. Did they send the part over to a repair shop in your area, to save you from hauling it all the way to Moncton. That would be a great help. Did they figure out what caused the bearing failure. I did lots of plowing snow this winter as well. I haven't had any trouble with the 7010 since I purchased it new, hope it stays that way.
/ Failed bearing 7010 #7
Yay! ... Will they tell you what happened? Sounds like one part caused a chain reaction to break the hub. ... But maybe simply a casting failure to let parts shift and jam up. :confused3:
Yup they send the parts to a local shop, all the shop could tell me is that the bearing failed and damaged other parts, it started making noise and the tractor was stopped immediately, oil poured out, end of story. As I said, hopefully a one-off, pleased with the tractor otherwise.
Interesting bucket, Ralph, haven't seen one quite like it.
/ Failed bearing 7010 #10
Just finished putting a new 5/8" wear plate on today. I just about have all the modifications done for another year.
/ Failed bearing 7010 #11
I like that bucket ... Front dozing, rear dragging. Nice. It's like a 4-in-1 opened up.
/ Failed bearing 7010 #12
I just put a new grader blade on the bottom, adding 2 1/2" to the height. Plowing down steep hills, the bottom edge wouldn't always touch the ground. I ran into the same problem this winter with a brand new angle plow I purchased. It was a no name brand from China sold to a guy for his Skidsteer. The correct height for the quick attach is critical. If you are always on level ground you would never know there was a problem. Something everyone should watch out for if you live in hilly country like myself. With the new 5/8" thick grader blade and back drag on the top I have added over 250 lbs.. The extra weight will also help with front end traction. I have all 4 tires studded as well, I used the Maxigrip studs. Expensive but they stay in. The only thing left to do is add a couple toe hooks and ready for next winter.
/ Failed bearing 7010 #13
Yeah, I have the P7040 with a front right bearing that let go at 324.6 hours...I'm going through **** trying to get it fixed...I will never buy an LS tractor again.
/ Failed bearing 7010 #14
A little late to the party guys, but there is a run of P Series tractors that have an update available. We've had 2 failures that I'm aware of but we do check every P Series that comes in for service and update as required. Your dealer needs to get the front axle s/n and call their regional service manager, if it's within a certain serial # range they *should* approve an update. So far all the updates we've done have been covered under warranty.
/ Failed bearing 7010 #15
You wouldn't happen to know what that range of s/n are? I have about 500 hours on my LS 7010 and would sooner have the update completed prior to any possible failure. Thanks.
/ Failed bearing 7010 #16
Sorry I don't remember the range, there is a s/n stamped in the front axle and that's what your dealer needs to check.
/ Failed bearing 7010 #17
Your front bearing probably failed because the wheel base on the front end is set at 7'. Reverse the rims so the wheel base is 6.5'. That extra 6 inches puts alot of strain on the bearings. If you check the wheel base on the rear end is 6.5'. LS 7010's have a common problem with the front bearings because of the wheel base set too wide. I shortened the front wheel base on my 2011 7010 as soon as I bought it and never had a problem.
/ Failed bearing 7010 #18
Good point, I will check and see what my 7010 wheel base is set at. How many hours do you have on your 7010?
/ Failed bearing 7010 #19
Just shy of 1000 hours. The tractor got worked pretty hard the first two years. Haying, plowing, manure spreading, bush cutting, snowblowing, etc. The only problem I had was 2 years ago during haying season the steering hydraulic hose had a slow leak at the coupling. Not a big deal. The dealership sent a mechanic down from Mirimichi within a day and replaced it. Pattersons has excellent service. I've been skidding logs with it the past two winters. The tractor works like a champ!
/ Failed bearing 7010 #20
Glad to hear you a very satisfied with Pattersons. I haven't had any trouble with my 7010 as well. I had a busy winter ploughing snow, just but the blowers and snow pusher away until next winter.
2003 Ford E-450 Super Duty Passenger Bus (A61573)
2003 Ford E-450...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A66736)
2017 Ford F-150...
2014 Nissan Versa Note Hatchback (A66738)
2014 Nissan Versa...
2013 WACKER NEUSON  LTN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
Metal Rooster Weather Vane (A66738)
Metal Rooster...
DYNAPAC  CP271 PNEUMATIC ROLLER (A67714)
DYNAPAC CP271...
