New 5055E
/ New 5055E #181
They have a substitute part for "AL181919" Spring Quantity 3, SUB FOR AL115253; which is the part which holds the compression disks against the friction disk and looks like the old star wheel adjusters from drum brakes based on the bad picture I'm seeing on JD's site.
What I can't figure out from their pictures is what pushes on the brake plates?
/ New 5055E #182
I experimented with my Kubota M9540 this afternoon. I have the same pedal movement in the first pump as I have in the tenth pump. I did not measure my pedal travel, sorry.
/ New 5055E #183
Same on my JD 5520
/ New 5055E #185
They sell a lot of the 5000E series at our nearest dealer. The sales manager himself has a 5083E cab, MFWD and Loader. My wife and son bought a 2011 5065M 2WD with cab and took delivery in June of 2012 and it has had none of problems mentioned in this thread, I read this thread from page 1 to the end. I went to Tractordata expecting to see the same engine in the 5065E as the 5065M but it's not. The M has a 5 cyl. and the E has a 3 cyl. I do know that the engine in the 5065M is made in Mexico, the Transmission is supposedly from China, the front 2WD axle is from India, the hydraulics are from Brazil and the cab is made in the US. Assembled in Augusta, GA not made there. Friend of mine took the Gold Key tour after ordering a 5115M and he said they do nothing but assemble tractors there.
The 5065M here may have 4000 lbs. of sprayer and contents behind it at a time or 3500 lbs. of DiscBine behind so you're talking close to 11-12K lbs. total, I'm sorry but good brakes are essential to safe operation.
This brake problem would be totally unacceptable on this farm. What's going to happen when they sell one to city maintenance dept. and no one tells the operator about the brakes and runs over someone or crashes it on the way to some park that needs some landscape work? My fear is that owner/operators that know of this problem and have documented it but continue to operate them and get into accident with one on the road I fear they're going to come back on the owner for knowingly and willingly operating a faulty piece of equipment. Also if someone is running a business with one and an employee has an accident and OSHA comes in who do think is going get the blame for it if it's a known problem? Not sure how or where the law stands on a situation such as this but it is something to think about.
/ New 5055E
I asked the service guy about my lemon tractor. Said it was an adjustment under the dash that need to be ran almost all the way out? I don't agree since the second push is firm. New tractor is great except for constant caution lights. Dealer came out and looked it over. Ordered a new fuel pump and tightened the negative battery post.
Good luck to everyone else with problems. Loading and unloading can be tricky but when this new tractor was brand new I took it across the creek with 1/2 tank of fuel. It sucked air and died rights as I was at the top. Had it done it in the other tractor and died, it wouldve been nerve racking having to pump the brakes to get it stopped
Brett
/ New 5055E #187
Hello rustyshakelford, I am going to give you cold sweats. With power brakes if the engine stalls you have a few seconds of foot brakes then nothing. You have to rip the hand brake on and hope it holds. Mine didn't.
/ New 5055E #188
:confused3:What hand brake are you talking about?
/ New 5055E #189
I thought there was a hand brake on the floor to the left of the seat. There is on the larger models as well as the park position on the gear stick.
/ New 5055E #190
Most JD utility tractors don't have "true power brakes" in the true sense of the words. The trans pump fills the brake valve but supplies "no pressure"(note the hose clamps) therefore in theory if brake disc pistons don't leak oil one could apply brake pedals many times without engine running and brakes would hold. JD hasn't changed the brake valve design much since the introduction of the 20 series so I wonder why the pedals on some newer models requires pumping? The following list of tractors utilizes the same brake valve.
2332 - 5200, 5300, 5400 and 5500 Tractors - 22Mar15 ( FR ES )
2615 - 5210, 5310, 5410 and 5510 Tractors - 22Mar15 ( FR ES )
2616 - 5310N and 5510N Tractors - 22Mar15 ( FR ES )
2845 - 5320N, 5420N and 5520N Tractors - 17Jul14 ( FR ES )
4413 - Tractors 5215, 5315, 5415, 5515, 5515 High Crop (European Edition) - 14Oct14 ( FR DE IT ES SV )
4414 - Tractors 5215F&V, 5315F&V, 5515F&V, 5615F&V (European Edition) - 14Oct14 ( FR DE IT ES SV )
4416 - 5303, 5403 and 5503 Tractors (PY5303E,PY5403E,PY5503E)(Turkey Version) - 22Mar15 ( TR )
4421 - 5310 (S.N. PY5310S005119- ) and 5203S (S.N. PY5203S000001 -) Tractors (India Edition) - 21Mar15
4433 - 5310S(PY5310T), 5410(PY5410S), 5610(PY5610T) Tractors (India Edition) - 21Mar15
4465 - 5303(PY5303C) and 5403(PY5403C) Tractor (North Africa Version) - 21Mar15
4469 - 5310,5610 (PY5310S,PY5610T) Tractors (Asian Edition) - 22Mar15
4476 - 5303 (PY5303E) and 5403(PY5403E) Tractors (South Africa Version) - 21Mar15
4480 - 5103, 5203, 5303 and 5403 Tractors (PY5103A,PY5203A,PY5303A,PY5403A)(Australia Edition) - 21Mar15
4481 - 5303 and 5403 (PY5303L, PY5403L) Tractors (South American Edition) - 21Mar15 ( PT ES )
4482 - 5303, 5403, 5503 Tractors (PY5303E,PY5403E,PY5503E) European Edition - 21Mar15 ( TR )
4501 - 5045D, 5045E, 5055D, 5055E, 5065E, 5075E Tractors (Engine: 3029TPY41, 3029TPY45, 3029TPY46, 3029TPY48)(North American 8X4/9X3 Transmission with OOS) - 22Mar15 ( FR ES )
4530 - 5100M Tractor (European Edition) - 22Jan15 ( FR DE IT ES SV )
4533 - 5045D,5045E,5055D,5055E,5065E,5075E Tractors (PY-5045B,5045U,5055B,5055U,5065U,5075U)(Australian 8X4/9X3-OOS Version) - 21Mar15
4534 - 5-750,5-754,5-800,5-804,5-850,5-854,5-900 Tractors, Manufactured by Tiantuo (NF) (China Edition) - 27Sep10
4538 - 5055E, 5065E and 5075E Tractors (European/Australian 9X3TSS-IOOS Version) - 22Mar15 ( FR DE IT PT ES )
4588 - 5070M Tractors (European Edition) - 22Jan15 ( FR DE IT ES SV )
4589 - 5080M Tractors (European Edition) - 22Jan15 ( FR DE IT ES SV )
4590 - 5090M Tractors (European Edition) - 22Jan15 ( FR DE IT ES SV )
4716 - 5055E Tractor (Engine 3029HPY36) (India Edition) - 21Mar15
4717 - 5060E Tractor (Engine 3029HPY37) (India Edition) - 21Mar15
4718 - 5065E Tractor (Engine 3029HPY38, 3029HPY49) (India Edition) - 21Mar15
4719 - 5075E Tractor (Engine 3029HPY39, 3029HPY50) (India Edition) - 21Mar15
6077 - 5415, 5415H, 5615, 5715 and 5715HC Tractors - 21Mar15 ( ES )
6081 - 5415 Narrow Tractor - 30Jan15 ( ES )
6088 - 5425(S.N.-002631), 5625(S.N.-001688) and 5725(S.N.-005047) Tractors (Manufactured in Monterrey) - 21Feb15 ( ES TR )
6101 - 5425(S.N. 002632-), 5625(S.N. 001689-) and 5725(S.N. 00504:cool: Tractors (Manufactured in Monterrey)(Worldwide Edition) - 30Jan15 ( ES TR )
6105 - 5083E Tractor (Engine 4045HP058)(Mexico Edition) - 22Mar15 ( FR IT ES TR )
6106 - 5093E Tractor (Engine PE4045HP059) - 21Mar15 ( FR IT ES TR )
6120 - 5076E Tractor (Worldwide Edition) - 22Mar15 ( FR PT RU ES )
6121 - 5076EL (Orchard) Tractor (Worldwide Edition) - 22Mar15 ( FR PT RU ES )
6122 - 5076EF (Narrow) Tractor (Worldwide Edition) - 22Mar15 ( FR PT ES )
6123 - 5082E Tractor (Worldwide Edition) - 22Mar15 ( FR PT RU ES )
6124 - 5090E Tractor (Worldwide Edition) - 22Mar15 ( FR PT RU ES )
6125 - 5090EL (Orchard) Tractor (Worldwide Edition) - 22Mar15 ( FR PT RU ES )
6126 - 5090EH (High Clearance) Tractor (Worldwide Edition) - 22Mar15 ( FR PT RU ES )
8543 - Tractor 5055E (South American Edition) - 03Feb15 ( FR PT ES )
8544 - Tractor 5065E (South American Edition) - 16Feb15 ( FR PT ES )
8548 - Tractor 5078E (South American Edition) - 16Feb15 ( FR PT ES )
8549 - Tractor 5085E (South American Edition) - 16Feb15 ( FR PT ES )
9197 - 5605 and 5705 Tractors - 04Aug14 ( PT ES )
9309 - 5103, 5203, 5303 and 5403 Tractors (PY5103U,PY5203U,PY5303U,PY5403U)(North American Edition) - 21Mar15 ( FR ES )
9310 - 5204(PY5204A) and 5303(PY5303M) Tractor (Mexico Version) - 21Mar15 ( ES )
9424 - 5220 and 5320 Tractors - 22Mar15 ( FR ES )
9425 - 5420 and 5520 Tractors - 22Mar15 ( FR ES )
9558 - 5600, 5700 Tractors (South America) - 03Feb15 ( PT ES )
9645 - 5603 Tractor - 22Mar15 ( FR ES )
9669 - 5603 Tractor (South American Edition) - 04Aug14 ( PT ES )
9817 - 5101E Limited / 5101E Tractor (Engine 4045HLV56,4045TLV64) - 22Mar15 ( FR RU ES )
9818 - 5083E Limited / 5083E Tractor (Engine 4045HLV53,4045TLV56) - 22Mar15 ( FR RU ES )
9819 - 5093E Limited / 5093E Tractor (Engine 4045HLV54,4045TLV60) - 22Mar15 ( FR RU ES )
9945 - 5083EN Tractor (North American Edition) - 22Mar15 ( FR RU ES )
9946 - 5093EN Tractor (North American Edition) - 22Mar15 ( FR RU ES )
9947 - 5101EN Tractor (North American Edition) - 22Mar15 ( FR RU ES )
9955 - 5075E Tractor (South American Edition) - 06Mar15 ( FR PT ES )
9987 - 5303, 5403 Tractor (Mfg. in Brazil)(South American Edition) - 03Feb15 ( PT ES )
10540 - 5065M Tractor (Engine 5030HLV11)(IT4) - 22Mar15 ( FR IT PT ES TR )
10541 - 5075M Tractor (Engine 5030HLV11)(IT4) - 22Mar15 ( FR IT PT ES TR )
10542 - 5085M Tractor (Engine 4045HLV53,4045HLV54)(Tier 3) - 22Mar15 ( FR IT PT ES TR )
10543 - 5095M Tractor (Engine 4045HLV52,4045HLV55)(Tier 3) - 22Mar15 ( FR IT PT ES TR )
10544 - 5095MH Tractor (Engine 4045HLV52)(Tier 3) - 22Mar15 ( FR IT PT ES TR )
10545 - 5105M Tractor (Engine 4045HLV50)(Tier 3) - 22Mar15 ( FR IT PT ES TR )
10546 - 5105ML Tractor (Engine 4045HLV50)(Tier 3) - 22Mar15 ( FR IT PT ES TR )
10844 - 5325N Tractor - 18Nov14 ( FR ES )
10845 - 5425N Tractor - 22Mar15 ( FR ES )
10846 - 5525N Tractor - 22Mar15 ( FR ES )
10865 - 5225 Tractor - 18Nov14 ( FR ES )
10866 - 5325 Tractor - 18Apr13 ( FR ES )
10867 - 5425 Tractor - 22Feb15 ( FR ES )
10868 - 5525 Tractor - 22Feb15 ( FR ES )
10869 - 5625 Tractor - 22Feb15 ( FR ES )
10967 - 5400N Tractor - 18Nov14 ( FR ES )
10968 - 5500N Tractor - 18Nov14 ( FR ES )
11015 - 5085M Tractor (Engine 4045HLV68,4045HLV70)(iT4) - 22Mar15 ( FR ES )
11016 - 5100M Tractor (Engine 4045HLV68,4045HLV70)(iT4) - 22Mar15 ( FR ES )
11017 - 5100MH Tractor (Engine 4045HLV68,4045HLV70)(iT4) - 22Mar15 ( FR ES )
11018 - 5115M Tractor (Engine 4045HLV68,4045HLV70)(iT4) - 22Mar15 ( FR ES )
11019 - 5115ML Tractor (Engine 4045HLV68,4045HLV70)(iT4) - 22Mar15 ( FR ES )
11400 - 5090E Tractor (South American Edition) - 16Feb15 ( FR PT ES )
11532 - 5050E Tractor (Turkey Edition) - 21Mar15
11743 - 5055E Tractor (Engine: 3029TPY21, 3029TPY38, 3029TPY50) (North American Edition, 9X3 TSS and 12X12 PR Transmission) - 21Mar15 ( FR ES )
11744 - 5065E Tractor (North American Edition, 9X3 TSS and 12X12 PR Transmission) - 21Mar15 ( FR ES )
11745 - 5075E Tractor (North American Edition, 9X3 TSS and 12X12 PR Transmission) - 22Mar15 ( FR ES )
11746 - 5055E Tractor (For Europe, Australia and New Zealand; 9X3 TSS and 12X12 PR Transmission) - 21Mar15 ( FR DE IT PT ES )
11747 - 5065E Tractor (For Europe, Australia and New Zealand; 9X3 TSS and 12X12 PR Transmission) - 21Mar15 ( FR DE IT PT ES )
11748 - 5075E Tractor (For Europe, Australia and New Zealand; 9X3 TSS and 12X12 PR Transmission) - 21Mar15 ( FR DE IT PT ES )
11913 - 5050E Tractor (Indian Edition) - 21Mar15
11933 - 5085E Tractor (Engine: 4045HLV69, iT4)(North American Edition) - 22Mar15 ( FR ES )
11934 - 5100E Tractor (Engine: 4045HLV69, iT4)(North American Edition) - 22Mar15 ( FR ES )
11983 - 5045E Tractor (Engine:3029HYP61, Final Tier 4)(North American Edition) - 22Mar15 ( FR ES )
11984 - 5055E Tractor (Engine:3029HYP61, 3029HPY62, Final Tier 4)(North American Edition) - 22Mar15 ( FR ES )
11985 - 5065E Tractor (Engine:3029HYP61, 3029HPY62, Final Tier 4)(North American Edition) - 22Mar15 ( FR ES )
11986 - 5075E Tractor (Engine:3029HYP61, 3029HPY62, Final Tier 4)(North American Edition) - 22Mar15 ( FR ES )
12050 - 5085M Tractor (S.N. 500001- )(Engine 4045HLV70)(European Edition) - 22Mar15 ( NL FI FR DE IT PT ES SV TR )
12051 - 5100M Tractor (S.N. 500001- )(Engine 4045HLV70)(European Edition) - 22Mar15 ( NL FI FR DE IT PT ES SV TR )
12052 - 5115M Tractor (S.N. 500001- )(Engine 4045HLV70)(European Edition) - 22Mar15 ( NL FI FR DE IT PT ES SV TR )
12179 - 5085ML Tractor (Engine 4045HLV68,4045HLV70)(North American Edition) - 22Mar15 ( FR ES )
12180 - 5100ML Tractor (Engine 4045HLV68,4045HLV70)(North American Edition) - 22Feb15 ( FR ES )
12211 - 5075M Tractor (European Edition)(Engine 3029HPY65, Final Tier 4) - 14Dec14 ( FR DE IT PT ES TR )
12226 - 5055E Tractor (South Africa and MENA Edition, Engine: 3029TPY26, 3029TPY42) - 21Mar15
12227 - 5065E Tractor (South Africa and MENA Edition, Engine: 3029TPY27, 3029TPY43) - 21Mar15
12228 - 5075E Tractor (South Africa and MENA Edition, Engine: 3029TPY28, 3029TPY44) - 21Mar15
12256 - 5075EF Tractor (Engine: 3029TPY60)(South American Edition) - 06Mar15 ( PT )
12272 - 5055E Tractor (JD Asia and Central Africa Edition, Engine: 3029DPY01) - 22Mar15 ( FR PT )
12302 - 5045E Tractor (Engine 3029TJ002)(CKD Argentina Edition) - 22Mar15 ( ES )
12303 - 5065E Tractor (Engine 3029TJ003, 3029TPY39)(CKD Argentina Edition) - 22Mar15 ( ES )
12304 - 5075E Tractor (Engine 3029TJ004, 3029TPY40)(CKD Argentina Edition) - 21Mar15 ( ES )
12306 - 5085E Tractor (Engine 4045HLV69)(European Edition) - 22Mar15 ( NL FI FR DE IT PT ES SV TR )
12307 - 5095E Tractor (Engine 4045HLV69)(European Edition) - 22Mar15 ( NL FI FR DE IT PT ES SV TR )
12397 - 5075M Tractor (North American Edition)(Engine:3029HYP65)(Final Tier 4) - 14Dec14 ( FR ES )
12563 - 5085M Tractor (Engine 4045HLV72)(North American Edition)(FT4) - 22Mar15 ( FR ES )
12564 - 5100M Tractor (Engine 4045HLV72)(North American Edition)(FT4) - 22Mar15 ( FR ES )
12565 - 5115M Tractor (Engine 4045HLV72)(North American Edition)(FT4) - 22Mar15 ( FR ES )
12566 - 5100MH Tractor (Engine 4045HLV72)(North American Edition)(FT4) - 22Mar15 ( FR ES )
/ New 5055E #191
Nope just the park position on the gear shift on the right.
/ New 5055E #192
Interestingly, my Kubota is the same way, no brake lock.
On the other hand my 30 year old Ford has brake pedal lock and a hand park brake that locks both the front axle and rear axle. Go figure....
/ New 5055E #193
Don't ever try to put tractor in that "park" notch with the tractor moving. There is a thread here somewhere about someone that did that and the damage caused. I an't recall the details but it was very expensive.
/ New 5055E #194
Correct. You're only options are , throttling back to idle or dropping the bucket and/ or whatever tool you have on the 3PH if you have something on and raised. I wouldn't even try to shift down a gear being afraid to not make it back into a gear.
/ New 5055E #195
Most JD utility tractors don't have "true power brakes" in the true sense of the words. The trans pump fills the brake valve but supplies "no pressure"(note the hose clamps) therefore in theory if brake disc pistons don't leak oil one could apply brake pedals many times without engine running and brakes would hold. JD hasn't changed the brake valve design much since the introduction of the 20 series so I wonder why the pedals on some newer models requires pumping? The following list of tractors utilizes the same brake valve. 2332 - 5200, 5300, 5400 and 5500 Tractors - 22Mar15 ( FR ES ) 2615 - 5210, 5310, 5410 and 5510 Tractors - 22Mar15 ( FR ES ) 2616 - 5310N and 5510N Tractors - 22Mar15 ( FR ES ) 2845 - 5320N, 5420N and 5520N Tractors - 17Jul14 ( FR ES ) 4413 - Tractors 5215, 5315, 5415, 5515, 5515 High Crop (European Edition) - 14Oct14 ( FR DE IT ES SV ) 4414 - Tractors 5215F&V, 5315F&V, 5515F&V, 5615F&V (European Edition) - 14Oct14 ( FR DE IT ES SV ) 4416 - 5303, 5403 and 5503 Tractors (PY5303E,PY5403E,PY5503E)(Turkey Version) - 22Mar15 ( TR ) 4421 - 5310 (S.N. PY5310S005119- ) and 5203S (S.N. PY5203S000001 -) Tractors (India Edition) - 21Mar15 4433 - 5310S(PY5310T), 5410(PY5410S), 5610(PY5610T) Tractors (India Edition) - 21Mar15 4465 - 5303(PY5303C) and 5403(PY5403C) Tractor (North Africa Version) - 21Mar15 4469 - 5310,5610 (PY5310S,PY5610T) Tractors (Asian Edition) - 22Mar15 4476 - 5303 (PY5303E) and 5403(PY5403E) Tractors (South Africa Version) - 21Mar15 4480 - 5103, 5203, 5303 and 5403 Tractors (PY5103A,PY5203A,PY5303A,PY5403A)(Australia Edition) - 21Mar15 4481 - 5303 and 5403 (PY5303L, PY5403L) Tractors (South American Edition) - 21Mar15 ( PT ES ) 4482 - 5303, 5403, 5503 Tractors (PY5303E,PY5403E,PY5503E) European Edition - 21Mar15 ( TR ) 4501 - 5045D, 5045E, 5055D, 5055E, 5065E, 5075E Tractors (Engine: 3029TPY41, 3029TPY45, 3029TPY46, 3029TPY48)(North American 8X4/9X3 Transmission with OOS) - 22Mar15 ( FR ES ) 4530 - 5100M Tractor (European Edition) - 22Jan15 ( FR DE IT ES SV ) 4533 - 5045D,5045E,5055D,5055E,5065E,5075E Tractors (PY-5045B,5045U,5055B,5055U,5065U,5075U)(Australian 8X4/9X3-OOS Version) - 21Mar15 4534 - 5-750,5-754,5-800,5-804,5-850,5-854,5-900 Tractors, Manufactured by Tiantuo (NF) (China Edition) - 27Sep10 4538 - 5055E, 5065E and 5075E Tractors (European/Australian 9X3TSS-IOOS Version) - 22Mar15 ( FR DE IT PT ES ) 4588 - 5070M Tractors (European Edition) - 22Jan15 ( FR DE IT ES SV ) 4589 - 5080M Tractors (European Edition) - 22Jan15 ( FR DE IT ES SV ) 4590 - 5090M Tractors (European Edition) - 22Jan15 ( FR DE IT ES SV ) 4716 - 5055E Tractor (Engine 3029HPY36) (India Edition) - 21Mar15 4717 - 5060E Tractor (Engine 3029HPY37) (India Edition) - 21Mar15 4718 - 5065E Tractor (Engine 3029HPY38, 3029HPY49) (India Edition) - 21Mar15 4719 - 5075E Tractor (Engine 3029HPY39, 3029HPY50) (India Edition) - 21Mar15 6077 - 5415, 5415H, 5615, 5715 and 5715HC Tractors - 21Mar15 ( ES ) 6081 - 5415 Narrow Tractor - 30Jan15 ( ES ) 6088 - 5425(S.N.-002631), 5625(S.N.-001688) and 5725(S.N.-005047) Tractors (Manufactured in Monterrey) - 21Feb15 ( ES TR ) 6101 - 5425(S.N. 002632-), 5625(S.N. 001689-) and 5725(S.N. 00504:cool: Tractors (Manufactured in Monterrey)(Worldwide Edition) - 30Jan15 ( ES TR ) 6105 - 5083E Tractor (Engine 4045HP058)(Mexico Edition) - 22Mar15 ( FR IT ES TR ) 6106 - 5093E Tractor (Engine PE4045HP059) - 21Mar15 ( FR IT ES TR ) 6120 - 5076E Tractor (Worldwide Edition) - 22Mar15 ( FR PT RU ES ) 6121 - 5076EL (Orchard) Tractor (Worldwide Edition) - 22Mar15 ( FR PT RU ES ) 6122 - 5076EF (Narrow) Tractor (Worldwide Edition) - 22Mar15 ( FR PT ES ) 6123 - 5082E Tractor (Worldwide Edition) - 22Mar15 ( FR PT RU ES ) 6124 - 5090E Tractor (Worldwide Edition) - 22Mar15 ( FR PT RU ES ) 6125 - 5090EL (Orchard) Tractor (Worldwide Edition) - 22Mar15 ( FR PT RU ES ) 6126 - 5090EH (High Clearance) Tractor (Worldwide Edition) - 22Mar15 ( FR PT RU ES ) 8543 - Tractor 5055E (South American Edition) - 03Feb15 ( FR PT ES ) 8544 - Tractor 5065E (South American Edition) - 16Feb15 ( FR PT ES ) 8548 - Tractor 5078E (South American Edition) - 16Feb15 ( FR PT ES ) 8549 - Tractor 5085E (South American Edition) - 16Feb15 ( FR PT ES ) 9197 - 5605 and 5705 Tractors - 04Aug14 ( PT ES ) 9309 - 5103, 5203, 5303 and 5403 Tractors (PY5103U,PY5203U,PY5303U,PY5403U)(North American Edition) - 21Mar15 ( FR ES ) 9310 - 5204(PY5204A) and 5303(PY5303M) Tractor (Mexico Version) - 21Mar15 ( ES ) 9424 - 5220 and 5320 Tractors - 22Mar15 ( FR ES ) 9425 - 5420 and 5520 Tractors - 22Mar15 ( FR ES ) 9558 - 5600, 5700 Tractors (South America) - 03Feb15 ( PT ES ) 9645 - 5603 Tractor - 22Mar15 ( FR ES ) 9669 - 5603 Tractor (South American Edition) - 04Aug14 ( PT ES ) 9817 - 5101E Limited / 5101E Tractor (Engine 4045HLV56,4045TLV64) - 22Mar15 ( FR RU ES ) 9818 - 5083E Limited / 5083E Tractor (Engine 4045HLV53,4045TLV56) - 22Mar15 ( FR RU ES ) 9819 - 5093E Limited / 5093E Tractor (Engine 4045HLV54,4045TLV60) - 22Mar15 ( FR RU ES ) 9945 - 5083EN Tractor (North American Edition) - 22Mar15 ( FR RU ES ) 9946 - 5093EN Tractor (North American Edition) - 22Mar15 ( FR RU ES ) 9947 - 5101EN Tractor (North American Edition) - 22Mar15 ( FR RU ES ) 9955 - 5075E Tractor (South American Edition) - 06Mar15 ( FR PT ES ) 9987 - 5303, 5403 Tractor (Mfg. in Brazil)(South American Edition) - 03Feb15 ( PT ES ) 10540 - 5065M Tractor (Engine 5030HLV11)(IT4) - 22Mar15 ( FR IT PT ES TR ) 10541 - 5075M Tractor (Engine 5030HLV11)(IT4) - 22Mar15 ( FR IT PT ES TR ) 10542 - 5085M Tractor (Engine 4045HLV53,4045HLV54)(Tier 3) - 22Mar15 ( FR IT PT ES TR ) 10543 - 5095M Tractor (Engine 4045HLV52,4045HLV55)(Tier 3) - 22Mar15 ( FR IT PT ES TR ) 10544 - 5095MH Tractor (Engine 4045HLV52)(Tier 3) - 22Mar15 ( FR IT PT ES TR ) 10545 - 5105M Tractor (Engine 4045HLV50)(Tier 3) - 22Mar15 ( FR IT PT ES TR ) 10546 - 5105ML Tractor (Engine 4045HLV50)(Tier 3) - 22Mar15 ( FR IT PT ES TR ) 10844 - 5325N Tractor - 18Nov14 ( FR ES ) 10845 - 5425N Tractor - 22Mar15 ( FR ES ) 10846 - 5525N Tractor - 22Mar15 ( FR ES ) 10865 - 5225 Tractor - 18Nov14 ( FR ES ) 10866 - 5325 Tractor - 18Apr13 ( FR ES ) 10867 - 5425 Tractor - 22Feb15 ( FR ES ) 10868 - 5525 Tractor - 22Feb15 ( FR ES ) 10869 - 5625 Tractor - 22Feb15 ( FR ES ) 10967 - 5400N Tractor - 18Nov14 ( FR ES ) 10968 - 5500N Tractor - 18Nov14 ( FR ES ) 11015 - 5085M Tractor (Engine 4045HLV68,4045HLV70)(iT4) - 22Mar15 ( FR ES ) 11016 - 5100M Tractor (Engine 4045HLV68,4045HLV70)(iT4) - 22Mar15 ( FR ES ) 11017 - 5100MH Tractor (Engine 4045HLV68,4045HLV70)(iT4) - 22Mar15 ( FR ES ) 11018 - 5115M Tractor (Engine 4045HLV68,4045HLV70)(iT4) - 22Mar15 ( FR ES ) 11019 - 5115ML Tractor (Engine 4045HLV68,4045HLV70)(iT4) - 22Mar15 ( FR ES ) 11400 - 5090E Tractor (South American Edition) - 16Feb15 ( FR PT ES ) 11532 - 5050E Tractor (Turkey Edition) - 21Mar15 11743 - 5055E Tractor (Engine: 3029TPY21, 3029TPY38, 3029TPY50) (North American Edition, 9X3 TSS and 12X12 PR Transmission) - 21Mar15 ( FR ES ) 11744 - 5065E Tractor (North American Edition, 9X3 TSS and 12X12 PR Transmission) - 21Mar15 ( FR ES ) 11745 - 5075E Tractor (North American Edition, 9X3 TSS and 12X12 PR Transmission) - 22Mar15 ( FR ES ) 11746 - 5055E Tractor (For Europe, Australia and New Zealand; 9X3 TSS and 12X12 PR Transmission) - 21Mar15 ( FR DE IT PT ES ) 11747 - 5065E Tractor (For Europe, Australia and New Zealand; 9X3 TSS and 12X12 PR Transmission) - 21Mar15 ( FR DE IT PT ES ) 11748 - 5075E Tractor (For Europe, Australia and New Zealand; 9X3 TSS and 12X12 PR Transmission) - 21Mar15 ( FR DE IT PT ES ) 11913 - 5050E Tractor (Indian Edition) - 21Mar15 11933 - 5085E Tractor (Engine: 4045HLV69, iT4)(North American Edition) - 22Mar15 ( FR ES ) 11934 - 5100E Tractor (Engine: 4045HLV69, iT4)(North American Edition) - 22Mar15 ( FR ES ) 11983 - 5045E Tractor (Engine:3029HYP61, Final Tier 4)(North American Edition) - 22Mar15 ( FR ES ) 11984 - 5055E Tractor (Engine:3029HYP61, 3029HPY62, Final Tier 4)(North American Edition) - 22Mar15 ( FR ES ) 11985 - 5065E Tractor (Engine:3029HYP61, 3029HPY62, Final Tier 4)(North American Edition) - 22Mar15 ( FR ES ) 11986 - 5075E Tractor (Engine:3029HYP61, 3029HPY62, Final Tier 4)(North American Edition) - 22Mar15 ( FR ES ) 12050 - 5085M Tractor (S.N. 500001- )(Engine 4045HLV70)(European Edition) - 22Mar15 ( NL FI FR DE IT PT ES SV TR ) 12051 - 5100M Tractor (S.N. 500001- )(Engine 4045HLV70)(European Edition) - 22Mar15 ( NL FI FR DE IT PT ES SV TR ) 12052 - 5115M Tractor (S.N. 500001- )(Engine 4045HLV70)(European Edition) - 22Mar15 ( NL FI FR DE IT PT ES SV TR ) 12179 - 5085ML Tractor (Engine 4045HLV68,4045HLV70)(North American Edition) - 22Mar15 ( FR ES ) 12180 - 5100ML Tractor (Engine 4045HLV68,4045HLV70)(North American Edition) - 22Feb15 ( FR ES ) 12211 - 5075M Tractor (European Edition)(Engine 3029HPY65, Final Tier 4) - 14Dec14 ( FR DE IT PT ES TR ) 12226 - 5055E Tractor (South Africa and MENA Edition, Engine: 3029TPY26, 3029TPY42) - 21Mar15 12227 - 5065E Tractor (South Africa and MENA Edition, Engine: 3029TPY27, 3029TPY43) - 21Mar15 12228 - 5075E Tractor (South Africa and MENA Edition, Engine: 3029TPY28, 3029TPY44) - 21Mar15 12256 - 5075EF Tractor (Engine: 3029TPY60)(South American Edition) - 06Mar15 ( PT ) 12272 - 5055E Tractor (JD Asia and Central Africa Edition, Engine: 3029DPY01) - 22Mar15 ( FR PT ) 12302 - 5045E Tractor (Engine 3029TJ002)(CKD Argentina Edition) - 22Mar15 ( ES ) 12303 - 5065E Tractor (Engine 3029TJ003, 3029TPY39)(CKD Argentina Edition) - 22Mar15 ( ES ) 12304 - 5075E Tractor (Engine 3029TJ004, 3029TPY40)(CKD Argentina Edition) - 21Mar15 ( ES ) 12306 - 5085E Tractor (Engine 4045HLV69)(European Edition) - 22Mar15 ( NL FI FR DE IT PT ES SV TR ) 12307 - 5095E Tractor (Engine 4045HLV69)(European Edition) - 22Mar15 ( NL FI FR DE IT PT ES SV TR ) 12397 - 5075M Tractor (North American Edition)(Engine:3029HYP65)(Final Tier 4) - 14Dec14 ( FR ES ) 12563 - 5085M Tractor (Engine 4045HLV72)(North American Edition)(FT4) - 22Mar15 ( FR ES ) 12564 - 5100M Tractor (Engine 4045HLV72)(North American Edition)(FT4) - 22Mar15 ( FR ES ) 12565 - 5115M Tractor (Engine 4045HLV72)(North American Edition)(FT4) - 22Mar15 ( FR ES ) 12566 - 5100MH Tractor (Engine 4045HLV72)(North American Edition)(FT4) - 22Mar15 ( FR ES )
What a long list of models!! If all use the same or similar brakes...what changed??? Never recall hearing any brake or heating issues on the 5xx5 units.
/ New 5055E #196
Most north american tractors don't have both hand brake and service brakes. I know larger US built Deere's get a hand brake for export, but domestic market doesn't, just PARK on transmission.
/ New 5055E #197
My JD 4300 has a hand brake, as well as wheel brakes.
/ New 5055E #199
I think they do to save money. Every tractor here has a Park brake except the JD 5065M. They put them in all cars and they weigh a heck of a lot less than most tractors.
/ New 5055E #200
I am going to start a new thread on the brake problem. This one has gone astray... I will call it "John Deere 2013-2015, 5E series brake problem."
2012 INTERNATIONAL 4300 4X2 S/A 18FT NON CDL BOX TRUCK (A67148)
2012 INTERNATIONAL...
1994 Trailmaster Aluminum T/A 407 Chemical Tanker Trailer (A64194)
1994 Trailmaster...
2000 NEW HOLLAND 5554 BACK HOE (A66091)
2000 NEW HOLLAND...
Jack Daniels Metal Decorative Sign (A64557)
Jack Daniels Metal...
(INOP) 2022 MACK MD6 WATER TRUCK (A64280)
(INOP) 2022 MACK...
New - Front mount rototiller
New - Front mount...
