Backhoe Anyone?? 3ph backhoe for LS2023
/ Anyone?? 3ph backhoe for LS2023 #1
Bigfoot56
Florida
LS 2023H
I posted here 3 weeks ago, zero response. Was considering purchasing a Woodmaxx 3ph backhoe. I understand the advantages of a sub frame unit but money is an issue so considering a 3ph backhoe unit. Looking for feedback regarding anyone owning/operating any 3ph backhoe. Years back I owned a mini-excavator but I have zero experience with tractor mounted backhoes.
/ Anyone?? 3ph backhoe for LS2023 #2
I have a 9ft Woods hoe with a subframe, backhoes put a good amount of stress on a tractor, I wouldn't want to use one off the 3 point.
/ Anyone?? 3ph backhoe for LS2023 #3
There are quite a few threads on 3ph backhoes. Generally speaking, most folks agree they are a very bad idea. Some folks have had success with them, and others have broken their tractor in half. For the price of buying a 3ph backhoe, you might be able to rent a mini-excavator as many times as you need one to get all the tasks done....and it will be way faster.
Thanks for your response, I appreciate your time. I've also wondered how hard it would be to add my own subframe? Gonna keep collecting opinions before making any decisions. Probably end up spending the extra money on a full subframe unit. Always seems to be a fine line between frugal & foolish for me.
/ Anyone?? 3ph backhoe for LS2023 #5
I installed the woods subframe myself, I don't know what tractor you have but they offer subframes for a good number of tractors. It wasn't too bad a job for me it was pretty straight forward with decent instructions
I'll scoot around & see if I can locate any of those other threads. I've already ruled out the rental route. I work 50+ hrs a week so all the work to be done will be done in bits & pieces which would require just too many rentals. Also looking to pick up some more property adjacent to mine so even more work anticipated down the line. I'm in Florida so I'm digging in sand, no stones or hardpan in my area which is the only reason I would consider a 3ph backhoe other than the monetary issue. The majority of trees I need to take out are under 15"cal. Thanks for taking the time to respond, I'm soaking up as much info as possible.
/ Anyone?? 3ph backhoe for LS2023 #7
If you plan on digging out stumps I would not go the 3pt route. Stump pulling is probably the hardest job for these little hoes
/ Anyone?? 3ph backhoe for LS2023 #8
I'm well aware of the issues with 3PT backhoes. I've had several with subframes. I currently have a 3PT Woods on a Cat 2 hitch on a New Holland TN 75D. My dealer who doesn't recommend 3PT hoes was ok on this tractor. I've used it hard for 10 years piling many tough stumps and have torn 2 buckets. The Woods 3 PT is not flexible at all. It's a very solid rigid frame
Andy
/ Anyone?? 3ph backhoe for LS2023 #9
I'd be a little more confident on a larger tractor and cat 2 hitch. Which hoe do you have the 90x or something bigger
/ Anyone?? 3ph backhoe for LS2023 #11
That might be the dirtiest post on TBN :)
Pertaining to the thread, if 3pt backhoes were so bad for the tractor, why do so many companies make them? The more I think about buying a backhoe the more I lean towards getting a subframe mount.
I'd rather go the used route, so if someone has a 7' that fits a Kioti DS3510, feel free to drop me a PM.
/ Anyone?? 3ph backhoe for LS2023 #12
Ya everyone seems to make one but many will say a sub frame is recommended. I believe damage by a 3 point backhoe may cause warranty issues as far as having damage to the tractor covered. I'm sure there are some models of tractors that there just isn't a subframe made for because they aren't common enough to bother, in that case the 3pt would be the only choice. Id think with the frame mount it would be pretty tough to damage the tractor these little hoes aren't I overly powerful as backhoes go, just enough to be dangerous lol
2025 Fabrique 12' x 6' Dump Trailer (A62613)
2025 Fabrique 12'...
2018 Dodge Charger Sedan (A61569)
2018 Dodge Charger...
VERMEER S725TX STAND ON SKID STEER (A62129)
VERMEER S725TX...
UNUSED REMOTE CONTROLLED BULLDOZER (A62130)
UNUSED REMOTE...
2010 Unverferth 1225 Rolling Harrow (A63116)
2010 Unverferth...
2014 John Deere 650K LGP Crawler Tractor Dozer (A61567)
2014 John Deere...
