Help! B3200, bucket wont curl down! (dump)
/ Help! B3200, bucket wont curl down! (dump) #1
tobypineo
Fort Kent, Maine
Kubota B3200
All other loader functions work fine. Almost feels like there is binding in the valve, but I may be wrong. Any ideas? 150 hours on the tractor...easy hours mowing and snowblowing mostly.
/ Help! B3200, bucket wont curl down! (dump) #2
Check quick connects and then look at the joy stick mechanicals.
/ Help! B3200, bucket wont curl down! (dump) #3
That sounds just like the valve problems that some B2320/B2620 series tractors have seen,such as the B2620 of member sandyc.
Have not heard of the same problem on the B3200 though,as it may not even be the same valve.
Good Luck!
/ Help! B3200, bucket wont curl down! (dump) #4
Your QD's is the problem, they are not fully seated..
Reset them or replace
QD's were reseated...can't see any mssiing bolts or binding...taking to the dealer tomorrow. thanks for your help so far!
/ Help! B3200, bucket wont curl down! (dump) #6
Try swaping the curl and dump lines which should reverse the flow direction. If it still doesn't dump. Its your QD end on the hose. If it won't curl but now dumps its either the valve or the qd end on the valve.
/ Help! B3200, bucket wont curl down! (dump) #7
I supposed I could have said all the things that could go bad, not just the obvious.
debris, jamming up the spool
parts on the end of the spool defective, springs, etc
load check parts in spool
spool not actually moving
no fluid to spool
re-seating the QD's is one thing, but is fluid actually making it's way to the cyl
Valve failure! Thanks to Matt @ Harry's Motorsports in Presque Isle, Maine for chasing Kubota on this...and thanks to Kubota for covering this part! They didn't have to do that. I'm covering labor, but I'll take it! Thanks again to both.
/ Help! B3200, bucket wont curl down! (dump) #9
After my valve was replaced the FEL hasn't let me down. Believe that Kubota must have a known defect and they are making good on replacing them where necessary.
2020 International HX620 Quint Dump (A62613)
2020 International...
2001 Kubota L3010 (A64126)
2001 Kubota L3010...
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
Morbark 30/36 Wood Chipper (A62613)
Morbark 30/36 Wood...
2014 Ford Transit Connect Handicap Van (A61573)
2014 Ford Transit...
2021 Caterpillar 303.5E2 (A64126)
2021 Caterpillar...
