Truck Bed Protection
/ Truck Bed Protection #1
deere5105
South Mississippi
2008 John Deere 5303 MFWD, 2004 John Deere 5205
I am considering options on protecting new truck bed, 2014 F150 with 5.5' bed. Last vehicle I went with the spray in liner and had no problems. Previous trucks I used combinations of bed rail protectors and rubber mats. I am not terribly rough on truck bed and don't feel the spray in liner is worth the extra cost for my use. I am leaning toward what appears to be an industry standard 3/8" rubber bed mat and probably tailgate mat too. Will not require bed rail protectors as the truck comes standard with those in place. Stopped by one accessory store and salesman was not very supportive of the rubber tailgate mat due to number of holes drilled. I would have liked to have had tailgate step, but don't think I am willing to pay full price to swap out now. That would have took care of the tailgate question. I do realize that the tailgate mat can get "snagged" loading items and torn loose. One option may be to just skip the tailgate mat altogether.
Curious if any others have been this route and if so had any experiences that would steer me in another direction.
/ Truck Bed Protection #2
We do our own spay ins now. Kit is about $120 by Raptor on Amazon or Ebay. This is the real deal, no cheap Autozone stuff. I do order plastic tailgate protectors. They seem the best option.
Chris
Chris
And attach the plastic protectors with self-tapping screws? Had thought if going that route to try to find stainless fasteners and washers to prevent rusting.
/ Truck Bed Protection #4
deere 5105, the situation that you've described is stainless screws electrically connected to mild steel. This arrangement will protect the screws from rusting at the expense of the mild steel tailgate.
In a very dry environment I would expect very little rusting. But if the rubber mat were to "hold" moisture in and around this stainless steel/mild steel juncture you will have rusting there, and localized to the exposed area because the remainder of the tailgate is coated. Only the self-tapping thread/hole is exposed, so that location will do all of the cathodic protection of the stainless screws. SS screws don't really need protection but the bare steel will protect the screws anyway by sacrificing itself.
Heres another way to think about it. If you used zinc plated screws there, ---->and they rusted after some time<--- they have sacrificed all of their zinc coating to protect the screws and tailgate from rusting. After some time, the zinc has depleted then you start to see steel rusting. It could be screw only, or screws and tailgate. If you use stainless steel screws there, the screw itself will never rust, but there's still the same amount of electrolysis occurring, and it's your tailgate being sacrificed while the screws are fine. Steel and stainless is not a good combination to use in an outdoor environment. You may notice the Auto mfr doesn't use stainless fasteners. I don't know what coating they use on their exposed fasteners, it might be zinc plus a sealer.
All of this is a moot point if there is no water. And it all gets worse if there's an electrolyte in the water (salt?)
/ Truck Bed Protection #5
Screws will not rust- the sheet metal that they go into will rust worse because you have broken the paint there. Worked at a Ford dealer and the best truck trade ins had a plastic insert that had the bed coated with good old paste wax. This was done before going to Ziebart. Customer had done it himself and never wiped the wax off. We pulled the liner and tossed it during reconditioning. Bed looked new.
/ Truck Bed Protection #6
Disclosure....I spray Gatorhyde bedliners as a business so I am biased......would never consider a drop in liner as they always hold moisture and will rub the paint raw as they move around over the years and of course cause rust. Look around for an independent guy to spray the truck properly...avoid the high cost franchise places like Rhino and you should be able to get it done for under $400...just make sure the technicians knows what he is doing. Bed should be scuffed up good for adhesion....don't let then use just a cleaning agent. Good luck and enjoy the new truck.
/ Truck Bed Protection #7
On my current and previous trucks I have a hard shell locking tonneau cover so opted for what is called a bed rug. Basically a bed rug is custom fitted carpet which covers the floor, 3 side walls and tailgate and keeps the actual metal like new. Chevy has them in their online accessories and they are also available aftermarket.
On 2 trucks prior to those I had the spray in rubberized liner which held up very well. When I traded in those trucks the dealer and new owners they sold them to were very happy to see a pickup bed that was clean and wasn't all dinged up.
I tried the plastic drop in liners on previous trucks without a cap or cover. I found that water from rain or snow would get in between the liner and the bed and would start to rust the bed.
IMO if you have a cap or tonneau cover to keep the weather out you can use the rubber mat, bed rug, spray in or plastic drop in liner. If the bed is uncovered I would only use the spray in liner. A rubber mat will work but water can get in between it and the bed.
/ Truck Bed Protection #8
Previous truck I waxed the bed well and put in a drop in liner. 10 years later when I sold the truck the bed was perfect.
Current truck I brushed on liner (I think Rustoleum, but I'm not sure) after scuffing up the paint. then I installed a rubber fitted mat (bed only, not tailgate.) After 11 years there's a couple of spots that I might touch up where I dropped something heavy but there's no rust in the bed. I like the mat because it's so much easier on the knees than a bare bed or a liner.
Unless I was expecting very heavy duty service, I would just do the bed myself instead of paying for a commercial spray job. It's a pretty easy task and only costs about $50.
/ Truck Bed Protection #9
George is pretty much right on...you have to judge what type of work you doing.....if you are just hauling you groceries and you have a cap then no big deal....if you use it like a truck then in my humble if slightly biased opinion a spray in is essential
/ Truck Bed Protection #10
I too, use a hard (tri-fold) tonneau cover. I've had drop-in liners & find them too slick for my use. I use 1/2" plywood or chip board in mine.
/ Truck Bed Protection #11
I had an old GMC that worked as a plow truck.
Had it painted by a 'back yard' painter and his advise was to smear the entire bed with grease B4 putting the liner back in.
Worked so well that after plowing (working it to death) for 8 years I actually sold it for $1000. more that I had paid for it.
But then I did buy it right at an auction and kept in good mechanical condition.
Actually paid 4k all in all and sold for 5k.
/ Truck Bed Protection #12
Bought new, my '99 SuperDuty has a 1/2" rubber custom mat (6.5 ft bed). It's sort of a garage queen, but has done a lot of work too. About once every other year I pull the mat, wash and rewax the bed. It still looks new after 15 years. The rubber is easy on the knees and has some traction to minimize sliding. Two side boxes have to be undone for access. My tailgate has an aluminum over the top edge that takes some punishment without much showing.
Cheers,
Mike
/ Truck Bed Protection #13
I don't have a bed liner in my new truck, and after 10 months of typical use it is holding up fine with a nice patina of light scratches but no scuffs or scrapes. That includes bringing home all the lumber and materials to build a 16'x24' boat house, and regular weekly or bi-weekly trips to the lumberyard in my never-ending project schedule. When I hauled cement blocks and a rental plate compactor, I put down scraps of OSB first, but otherwise everything gets loaded right on top of the paint and I don't baby it. Heavier loads and bulk materials (gravel, mulch, etc) go on my 7x16 trailer since it's better for that.
My past experience with work trucks showed that drop in bed liners are too slippery, spray-on is too grippy, and rubber mats bunch up when loading/unloading. Trucks with bare beds don't have any of those downsides. If your usage isn't severe and you're not afraid of light scratches, go for it. I'll say this, I think anything that involves drilling holes and putting screws in is worse than doing nothing at all.
deere 5105, the situation that you've described is stainless screws electrically connected to mild steel. This arrangement will protect the screws from rusting at the expense of the mild steel tailgate. In a very dry environment I would expect very little rusting. But if the rubber mat were to "hold" moisture in and around this stainless steel/mild steel juncture you will have rusting there, and localized to the exposed area because the remainder of the tailgate is coated. Only the self-tapping thread/hole is exposed, so that location will do all of the cathodic protection of the stainless screws. SS screws don't really need protection but the bare steel will protect the screws anyway by sacrificing itself. Heres another way to think about it. If you used zinc plated screws there, ---->and they rusted after some time<--- they have sacrificed all of their zinc coating to protect the screws and tailgate from rusting. After some time, the zinc has depleted then you start to see steel rusting. It could be screw only, or screws and tailgate. If you use stainless steel screws there, the screw itself will never rust, but there's still the same amount of electrolysis occurring, and it's your tailgate being sacrificed while the screws are fine. Steel and stainless is not a good combination to use in an outdoor environment. You may notice the Auto mfr doesn't use stainless fasteners. I don't know what coating they use on their exposed fasteners, it might be zinc plus a sealer. All of this is a moot point if there is no water. And it all gets worse if there's an electrolyte in the water (salt?)
Sounds kind of like the truck becomes a cathodic protection system for the fasteners. Had not considered that issue. My guess is your background is showing through on that explanation!
I don't have a bed liner in my new truck, and after 10 months of typical use it is holding up fine with a nice patina of light scratches but no scuffs or scrapes. That includes bringing home all the lumber and materials to build a 16'x24' boat house, and regular weekly or bi-weekly trips to the lumberyard in my never-ending project schedule. When I hauled cement blocks and a rental plate compactor, I put down scraps of OSB first, but otherwise everything gets loaded right on top of the paint and I don't baby it. Heavier loads and bulk materials (gravel, mulch, etc) go on my 7x16 trailer since it's better for that. My past experience with work trucks showed that drop in bed liners are too slippery, spray-on is too grippy, and rubber mats bunch up when loading/unloading. Trucks with bare beds don't have any of those downsides. If your usage isn't severe and you're not afraid of light scratches, go for it. I'll say this, I think anything that involves drilling holes and putting screws in is worse than doing nothing at all.
I agree with your descriptions of each system and I too would use a trailer before hauling too much in the truck bed. Think I still have an old mat or two in the barn, but may opt to get a new one that is made to fit the 5.5' bed. Just don't see me getting $400 worth of benefit from the spray in. I do agree for total protection they are about the best thing going. May just skip the tailgate.
/ Truck Bed Protection #16
Rubber mats work pretty good but they trap dirt, grime, and moisture under them. I don't like a rubber mat on the tailgate because you have to screw it to the tailgate. A rubber mat on the tailgate would be easy to catch something on. A rubber mat can be stolen and they can blow out if the tail gate it down. I think a spray in (Linex) is the way to go.
/ Truck Bed Protection #17
I just lay a sheet of plywood on the bed floor, and dump some diesel in there once in a while. on the tailgate I have a piece of plywood screwed on with about eight screws. That makes the bed and tailgate the same level. When I wanna clean the truck out,I just pull the plywood out, hose it out and put the wood back in there. Stuff doesn't slide around, doesn't make a lot of racket, and I never could see the value of a bed liner. I just run the truck because it is a truck
/ Truck Bed Protection #18
The ones I get utilize the factory screws already in the tailgate.
Chris
/ Truck Bed Protection #20
I suppose it depends on how you use your bed. I have had both drop in liners and the Linex brand professionally sprayed on. Personally I like the Linex liner and will never go back to a drop in or mat. It is easy to clean, isn't slippery or have big grooves that collect crap like drop in bed liners, doesn't trap moisture, debris, etc. and doesn't reduce volume. My :2cents:
2019 Chevrolet Malibu Sedan (A61574)
2019 Chevrolet...
2018 Freightliner Thor Venetian 400XCR A40 41ft. Class A Motorhome (A61574)
2018 Freightliner...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A63689)
Neckover GL24-2-7K...
100" Bucket (A64119)
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
LOT OF SCRAP WOOD AND TIN (A63291)
LOT OF SCRAP WOOD...
