How much can I lift with the FEL on a L4200?
   / How much can I lift with the FEL on a L4200? #1
swede4198
Kubota BX2320
I bought a used L4200 with a front end loader but I have no idea how much weight it will lift. I am adding on to a log cabin and plan to remove the bucket and replace it with a skid loader attachment plate with a set of 2,400 pound rated forks to take off the logs from the truck when it arrives but I can't find any idea what the max lift can be. The tractor has 1/2 loaded tires plus I will use a 6 foot box blade as a counter weight. Any ideas?
   / How much can I lift with the FEL on a L4200? #2
The factory FEL's are rated" approximately "double the number on the loader.I.E. 854x2=1708lbs.Or more specific the loaders are rated in kilo's(2.2lbs.)If you don't have a factory loader,don't know.
   / How much can I lift with the FEL on a L4200? #3
Like nybirdman says......Kubota FEL attachments lift capacity is specified by its model number. The LA534 on my B2650HSDC is rated at 534kg (or 534x2.2=1174.8 lbs).
   / How much can I lift with the FEL on a L4200? #4
Keep in mind the ratings are at the pivot points and two feet out like on a set of forks bolted to the bucket, it would be much less. I don't think my LA504 can lift 1100 lbs. I can lift my screening plant at 700 lbs, barely, not with the lift arms but by curling the bucket, but it is 4 ft deep so extends at least 6ft from the pivot point.
   / How much can I lift with the FEL on a L4200? #5
That great info never new that numbers on loader had anything to do with lift rating.
   / How much can I lift with the FEL on a L4200? #6
Also keep in mind you have to subtract the weight of your attachment. If your forks weigh 300lbs, thats 300lbs off the rating.
I also didn't know about the loader info. Since I have a LA680 I should be able to lift 1,000 pounds of logs with a skid loader attachment plate instead of the bucket and a set of 2,500# forks.
   / How much can I lift with the FEL on a L4200? #8
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2006 JLG SKY TRAK L10 10054 FORKLIFT (A50322)
2006 JLG SKY TRAK...
UNUSED AGT KRW23 WHEEL LOADER (A51243)
UNUSED AGT KRW23...
74in FEL HD Round Back Bucket (A52128)
74in FEL HD Round...
UNUSED FUTURE SKID STEER QUICK ATTACH TRENCHER (A51244)
UNUSED FUTURE SKID...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
