2810 gear rear axle seal picture thread
   / 2810 gear rear axle seal picture thread #1
Texan4Life
Gold Member
Texas
Mahindra 2810, IH Hydro 70, 706
As promised here are the pics plus some brief explanations of what I was doing. Hopefully this is helpful to others.
wheel and 3pt arm removed, oil drained:
http://i41.tinypic.com/oj35td.jpg
Loader brace and bottom axle bracket removed:
http://i44.tinypic.com/e712si.jpg
fender to axle mount removed:
http://i41.tinypic.com/bfrpsm.jpg
http://i42.tinypic.com/6huoft.jpg
disconnect brake linkage and remove axle housing to transmission bolts:
http://i43.tinypic.com/111kz91.jpg
axle housing removed:
http://i43.tinypic.com/bfqjwp.jpg
Backside of axle housing:
http://i42.tinypic.com/anh69v.jpg
With the bull gear and bearing removed (wrapped in paper towels and set aside) you can get to he large retaining ring. Odd on the other side this was two half circle clips that just cam off when the gear was removed. This side had single spring clip. Was a bear to get off, I like the two halves better.
http://i42.tinypic.com/f22f7r.jpg
Here is the recessed area on the gear where the retaining ring rides:
http://i42.tinypic.com/vevrq0.jpg
axle assembly removed from housing and disassembled:
http://i39.tinypic.com/2pre3iq.jpg
the old seal:
http://i40.tinypic.com/30hrceo.jpg
cleaned seal housing and applied RTV to outer seal edge of the new seal:
edit: forgot to mention that the separate edge I'm holding onto turns so don't apply any there.
http://i41.tinypic.com/15zk2ef.jpg
seal started:
http://i41.tinypic.com/3d74k.jpg
I used the bearing with the snap ring to drive the seal. this makes it easy to get the seal at the exact depth:
http://i43.tinypic.com/2z69urp.jpg
Clean off excess RTV with paper towel:
http://i39.tinypic.com/faoe36.jpg
when RTVing the seals I use the smallest bead i can make with the RTV applicator tip and then use my finger to smear it:
http://i40.tinypic.com/vs04yt.jpg
http://i44.tinypic.com/2n9hmdg.jpg
back on the shaft with the excess rtv showing:
http://i44.tinypic.com/savzw8.jpg
Excess clean off:
http://i40.tinypic.com/apc2c.jpg
bearing and tube spacer back on the shaft. decided to use a little rtv on each side of the paper gasket for good measure:
http://i42.tinypic.com/2hcgs4z.jpg
http://i41.tinypic.com/dg6lok.jpg
Bolted back on the housing:
http://i42.tinypic.com/2yua912.jpg
retaining ring, gear, and bearing back on the shaft. and the housing back on:
http://i39.tinypic.com/2cieo3q.jpg
finish reassembly and done. I like to wait until the next day for the rtv to cure before refilling with oil.
   / 2810 gear rear axle seal picture thread #3
is this good for gear driven 2810 or hydro. I have gear driven
   / 2810 gear rear axle seal picture thread #5
thanks, I was wondering how hard was it to get the bull gear off ? Did you pry it off or need a puller?
also was the housing hard to remove?
thanks in advance
thanks in advance
The bull gear just slides on, no puller needed. But if i remember correctly some soft taps with a rubber hammer helps.
The housing is bulky. a jack under the housing is a big help to take it off and line it up when putting it back on. A second person also helps when lining it back up.
   / 2810 gear rear axle seal picture thread #7
Found this very helpful Texan . Thank you. I'm surprised to see no brake shoes in this tear down. Ya think they would be some where near here.
your correct, the wet type (runs in oil) brake disc would be behind the pinion gear. you can see the gold colored bolts holding a plate on in the pic of the housing.
Our 2810 has been doing great.. this repair was done about 4yrs ago. doesn't leak a drop :)
   / 2810 gear rear axle seal picture thread #9
thanks, going to wait for parts to come in, Thursday. I will tackle it then.
thanks for your info
   / 2810 gear rear axle seal picture thread #10
What a pain in the neck to get to if one had to replace discs. The old JD I used to own had an exposed plate to unbolt and the pads were right there. They were of the dry type however.
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2020 CATERPILLAR 299D3XE SKID STEER (A51242)
2020 CATERPILLAR...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
Kubota RTV 900 Side By Side (RUNS) (A50774)
Kubota RTV 900...
UNUSED JCT SKID STEER QUICK ATTACH HAYSPEAR (A51244)
UNUSED JCT SKID...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
