Dowsing, Devining, 'Witching' for Water
   / Dowsing, Devining, 'Witching' for Water #31
James, I think that prize money is up to $1,000,000 now...to prove any "paranormal" activity.
That said, I have been known to handle the bent rods in the past, just playing around. The old mind sure can make those rods move :) you can find anything if you know where it's at!!
   / Dowsing, Devining, 'Witching' for Water #32
Yep, it is a million now. Go get it boys!:)
The Million Dollar Challenge - JREF
I don't know if dowsing would actually qualify for the Million Dollar Challenge. There's got to be some explanation for it... some people can, some people can't and those that can have varying degrees of 'accuracy'.
The 'tool' used is basically an extension of the person with the ability. Rods, Y branch of various tree types. a Mate of mine also wraps some solid-core copper wire around the end of a willow Y branch.
Scientifically, the head of the CSIRO (Australia's Government Science boffins) is investigating trying to come up with an instrument to replicate the phenomena as locating good water sources, in the Outback, for the mining industry is very important.
   / Dowsing, Devining, 'Witching' for Water #34
It doesn't look to tough to get registered for the One million dollar challenge. And it does not matter what country you live in. It would be helpful to get local media to examine your claim first, but a self made video would be considered. Not a lot of trouble for a million bucks US. I say go for it. If you can do it. I will point out that the water dowsing will be tested likely as in the past with plastic pipe with valves to channel running water in cross directions. You will need to be able to find the one with the running water. Should not be a problem, as this dowsing thing seems to work by some unknown to science mental power anyway. I notice the English gentleman did not have any trouble distinguishing between the copper pipe and the water bottle by "getting his mind right".
Here is the entry form.
View attachment mdc-rules-and-application-2011-03-09.pdf
   / Dowsing, Devining, 'Witching' for Water #35
I paid an old dude (90+ years old) to locate my well with divining rods...I was beyond skeptical although he nailed the location to the point that the well driller couldn't bail the well..That was 14 years ago and never a problem except for one pump konking out a week ago..Paid him less than $50 and that was at the drillers suggestion. He said that the only miss the guy ever had was locating a natural gas deposit instead of water. (didn't ask about the results of that one).
The diviner even tried to see if I could locate the water..Didn't work. He said he's only run into a few guys who could do it..He did try though and he never let me to believe in any mystery.
A neighbor brought a commercial divining thing up to locate my septic pipes and it nailed the location.. Dunno.
   / Dowsing, Devining, 'Witching' for Water #36
All I have to say, is anyone that thinks they have the skill/power/gift, then they should demonstrate the said same to get the million.. dowsing wells for $50 bucks vs. showing their skill off for a $1,000,000.00 is pretty darn stupid. Go Big or Go Home:)
   / Dowsing, Devining, 'Witching' for Water #37
Cant argue with the success that some people have doing it. my dad had one dowsed yrs ago. the guy pinpointed where 3 different sources crossed. hit plenty of water.
   / Dowsing, Devining, 'Witching' for Water #38
People like Carl Sagan just don't understand what this is all about. Or Michael Shermer (sp?) the skeptic. You can't explain it with science because it's not about that, and that doesn't mean it doesn't exist or is not valid.
How does ones pet know you are going to come home shortly? Without any schedule or beyond the range of auditory clues? A short while ago I saw a story on TV. Someone was in the hospital for critical reasons and in the midst of this, one of their beloved dogs went missing from home. It showed up at the hospital some distance away, clearly being seen on security video entering the hospital! It can't be explained in regular terms. Just like dowsing.
But for something to be total non-sense, the US government (CIA) sure spent alot of money on their Remote Viewing Efforts. See "MK Ultra"
   / Dowsing, Devining, 'Witching' for Water #39
I ran across this web site that explains the static electricity involved and why some are better at it.
"Divining rods and all common dowsing devices, are the simplest forms of electroscopes. The bent rod for example is just a variation of Gilbert's straw needle electroscope.
The divining rods are charged with static electricity from the dowser's own body. This static electricity can be seen quite adequately with a simple millivolt meter. This voltage is measured between the hands of the dowser, to measure this voltage accurately a diff amp should be used at the input to the voltmeter, "this eliminates stray signals which are common to both hands". The amount of voltage will vary depending on the person. A good dowser will have a high reading, "above 100 mv" while a poor dowser may read as low as,"0 mv.". For males the right hand is usually a negative polarity, and the left hand is positive in polarity. These polarities are usually reversed in females.
The divining rod charged positively will rotate in the dowsers hand to line up parallel to a negatively charged object being dowsed. A divining rod charged negatively will remain perpendicular to a negatively charged object being dowsed. This is because like charges repel, while unlike charges attract. Thus both bent divining rods are not required for dowsing. When two divining rods are used, and they are seen to cross, one of the rods is being moved to line up parallel with the charged object being dowsed. The other rod is moving to line up parallel to the first rod. A second reason for the two rods crossing is that of dowsing over an alternating current source, such as a pipeline or buried cable. these are usually buried shallow and are conducting ground currents as the path of least resistance."
Scientific Evidence of Dowsing
   / Dowsing, Devining, 'Witching' for Water #40
I ran across this web site that explains the static electricity involved and why some are better at it. "Divining rods and all common dowsing devices, are the simplest forms of electroscopes. The bent rod for example is just a variation of Gilbert's straw needle electroscope. The divining rods are charged with static electricity from the dowser's own body. This static electricity can be seen quite adequately with a simple millivolt meter. This voltage is measured between the hands of the dowser, to measure this voltage accurately a diff amp should be used at the input to the voltmeter, "this eliminates stray signals which are common to both hands". The amount of voltage will vary depending on the person. A good dowser will have a high reading, "above 100 mv" while a poor dowser may read as low as,"0 mv.". For males the right hand is usually a negative polarity, and the left hand is positive in polarity. These polarities are usually reversed in females. The divining rod charged positively will rotate in the dowsers hand to line up parallel to a negatively charged object being dowsed. A divining rod charged negatively will remain perpendicular to a negatively charged object being dowsed. This is because like charges repel, while unlike charges attract. Thus both bent divining rods are not required for dowsing. When two divining rods are used, and they are seen to cross, one of the rods is being moved to line up parallel with the charged object being dowsed. The other rod is moving to line up parallel to the first rod. A second reason for the two rods crossing is that of dowsing over an alternating current source, such as a pipeline or buried cable. these are usually buried shallow and are conducting ground currents as the path of least resistance." Scientific Evidence of Dowsing
Dangle $1,000,000 out there and see what happens, the research has started :) !!!
Midwestern Industries MEV Screen Model MEV 5X10-2 (A56435)
Midwestern...
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
2009 Honda Odyssey Van (A55758)
2009 Honda Odyssey...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
