Comparison Kobota L3301 vs Massey 1734e
   / Kobota L3301 vs Massey 1734e #1
Wideglide
Clarksburg,nj
Mf-210
Need advice on L3301 vs 1734E. Ready to pull trigger, 10% price difference, quality seems close,features are similiar Having hard time justifying $2000. more for Kobota. Any thoughts?
   / Kobota L3301 vs Massey 1734e #2
View attachment 417375 My new L3301. Real nice tractor. Nice, quick, responsive loader. Great power ( I went with the shuttle shift gear drive ), only 'cause I do not like hst. As far as the $2 grand goes, you'll get it back down the road when you sell, trade in, etc. And you will have the pleasure of owning a Kubota. I'm an Orange guy, what can I say???
How do you like loader capacity? Did u get Quick attach skid steer and have u used?
   / Kobota L3301 vs Massey 1734e #4
Those two tractors are nearly identical in specs & features.
1734e/L100 loader:
Machine base weight: 2734 lbs
HST PTO HP: 27.2
Hydraulic output: 10 GPM (6.2 implement)
3pt lift @ 24": 1600 lbs
Loader lift height: 98.6"
Loader lift weight @ full height: 1282 lbs
L3301/LA525 loader:
Machine base weight: 2734/2778 lbs
HST PTO HP: 26.2
Hydraulic output: 10.9 GPM (6.8 implement)
3pt lift @ 24": 1435 lbs
Loader lift height: 94.3"
Loader lift weight @ full height: 1134 lbs
So the Massey has a slightly better loader, 1 more HP at the PTO, and lifts a tad more on the 3pt. The machine weights are identical. They both use a treadle style HST pedal, which some people love, and some people hate. Overall, the machines are so, so, so close in every spec that it will come down to how each machine feels to you while using it.
Something else to mention, Massey offers a 5 year warranty, and I think the Kubota warranty is only 3 yrs. There's a lot of value in an extra two years of warranty, in addition to the $2000 you're already saving on the purchase price. Also, Massey usually offers better financing terms than Kubota.
Good luck! Both are good machines!
   / Kobota L3301 vs Massey 1734e #5
Of those two I would go with the Kubota. The Massey is probably a good choice as well, but as has been mentioned, Kubota resale is very good. you may very well get all your money back out if you choose to sell it down the road.
   / Kobota L3301 vs Massey 1734e #7
The loader is very quick and responsive, and yes, I got the QA FEL . I have put about 5 hours on it moving bucket loads of fire wood. So far, so good. I'm not to concerned on the loader capacity, as I also have an MX5100 with a fel.
Non- Running Asphalt Roller (A57454)
Non- Running...
10 ft Wrought Iron Fence (A56859)
10 ft Wrought Iron...
New/Unused Quick Attach Pallet Forks (A57453)
New/Unused Quick...
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
2022 Belgrade Steel 350 Barrel 65 Ton T/A Towable Cement Silo (A56858)
2022 Belgrade...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
