will it take off?
/ will it take off? #1,043
Because of this action, I see many, many lumps of coal in your stocking! ;)
But thats good. You can burn it in your woodstove.
larry
/ will it take off? #1,044
Killing this thread is very simple:
So, what do you guys think of our new President? :D
/ will it take off? #1,045
I think if he were in airforce 1 on a conveyor it would take off!! ...Even if none of his policies, ideals or ambitions do.
/ will it take off? #1,047
That plane hasnt taken off yet.
larry
/ will it take off? #1,050
NNNNOOOOOoooooo........
Why bring this up after a 7 year nap?
NNNNNNOOOOooooooo.......
Because it wasn't given the dirt nap it deserved.
I remember seeing this, around the time I joined TBN, and it made me wonder if I'd just made a big mistake.
/ will it take off? #1,051
Let us all remember that what makes an aircraft T A K E O F F is relative wind over the wings not how fast its wheels are turning or if it is moving forward over the terrain or backwards. When LIFT exceeds aircraft weight it takes off.
It is highly unlikely that the friction in the wheel bearings would be sufficient to generate a rearward motion force sufficient to exceed thrust by the margin required to prevent the aircraft from accelerating forward. (real world)
If however in your flight of fantasy problem statement the conveyor belt has unlimited speed and acceleration capabilities into relativistic realms the wheel bearings' friction could theoretically force the aircraft to remain motionless or go backwards. Likely real world bearings would fail but no big deal as if the conveyor belt can have "magic" bearings then why not the aircraft? If the aircraft's bearings are sufficiently low in friction then the aircraft will take off unless you want to accelerate your conveyor belt toward relativistic speeds and use the aircraft's wheel mass as something to ****** the aircraft's forward motion.
Given that the conveyor belt and the aircraft both have magic bearings the limiting factor will be the conveyor mechanism approaching relativistic speeds (in the limit, the speed of light.) Since the conveyor belt cannot exceed the speed of light its acceleration will approach zero in the limit. With no further acceleration the rotating aircraft wheels will no longer produce a retarding force and the aircraft will accelerate forward to take off.
It is possible that at some high speed the motion of the conveyor which pulls air with it forming a wind will at some high velocity provide a relative wind of sufficient velocity to generate sufficient lift to cause the aircraft to take off.
Patrick
/ will it take off? #1,052
By golly, Patrick, you're right!
Jim
/ will it take off? #1,053
Patrick
That ain't the only thing that generates sufficient wind..... :laughing:
/ will it take off? #1,054
No, no ,no; as the belt gets up to light speed it's mass is so great the plane sticks to it and gets dashed to smithereens on the rear roller.
/ will it take off? #1,055
Simply put the plane will take off even with its wheels spinning backwards at what ever speed the conveyor is turning them. There would not be sufficient drag to hold it still. Now if the plane was dependent on the wheels to power it to take off speed then we would have a plane that couldn't attain takeoff speed.
/ will it take off? #1,057
Patrick
Well summed.
No evidence that you understand the composite of what Patrick wrote. ... Simplism will not get you there.
.,,larry
/ will it take off? #1,059
Will a plane with jet propulsion take off?
Same principles apply if you are relying on forward motion to get air over the wing. ... Conceivable that a big tail mounted jet engine could suck enuf air over the wing to levitate a light airframe.
/ will it take off? #1,060
Well summed.
.,,larry
No evidence needed. Everyone is tryin to make a simple problem hard by adding magical bearings and such. Get real the plane will take off and it has been proven with an actual conveyor and a remote control plane. This question has been beat to death over the years since I was a kid but yet so many keep trying to make it a hard problem.
2019 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2019 ASV RT-25...
2019 JCB 3TS-8T High Flow Compact Track Loader Skid Steer (A61572)
2019 JCB 3TS-8T...
Kubota V3300-T Turbo Diesel Industrial Engine  84 HP  Pump Takeout (A63689)
Kubota V3300-T...
2021 BOBCAT T870 SKID STEER (A62129)
2021 BOBCAT T870...
LILLISTON 4R ROLLING CULTIVATOR (A63291)
LILLISTON 4R...
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
