I Still Hate My Tractor II
   / I Still Hate My Tractor II
Tuesday morning tractor funnies.....warranty? What warranty. I bet if I wanted to extend my protection they'd take my money no problem.
Fred
   / I Still Hate My Tractor II #152
Maybe warranty the Turbolator too!!
   / I Still Hate My Tractor II #153
Let it go Fred. Its not worth the personal aggravation. I still get mail for my dead father. Been gone for 18 years. Its hard to get off of mailing lists and I figure the joy is you can smile every time they waste their postage on you. Use it for kindling or line a birdcage with it. :)
   / I Still Hate My Tractor II #154
Now I'm upset, they never sent me such notice for either of my machines.
   / I Still Hate My Tractor II #155
Thats because yours never breaks down as often as "Freds" does.:eek::p
Well it's been a good Winter for the machine. It starts, runs well and has been there for me every time I needed it to blow the 140 inches we had this Winter. I should stop bitching right?
My good friend down the road bought a new 2013 Deere 4320 cab last Fall. It has 25 hours on it. Last weekend he brought it by my place because he was unable to connect the 3rd function hoses to his new Frost-Bite grapple (nice product by the way).
It has a super funky line setup (all Deere) that uses an electric solenoid at the rear of the tractor, then hoses going forward to the loader frame.
It turns out he couldn't release line pressure. I turned the key on engine off then cycled the 3rd function buttons but still no clickety click of the solenoid at the rear, Turns out you must have the engine running to get power to that solenoid making it useless to try that method of removing hose pressure. Finally found the manual bleed off valve in the rear so we were able to connect the hoses.
Also the door stays (stops if I may) are wimpy cables and not gas cylinders like the Botas have. He said one day he got home from work and one door laid on the ground after a wind storm, both hinges were broken clean off as was the flimsy cable. Dealer came and collected over-priced ($43K) machine and warrantied the hinges. He tells me this is the smallest USA tractor Deere makes, I wasn't too impressed with some of the machine although he likes it.
Rear wheels welded not bolted so making fine adjustments to the width is not possible. The only width adjustment is done by swapping wheels left and right.
Fred, always bitchin' about something.
   / I Still Hate My Tractor II #157
Well it's been a good Winter for the machine. It starts, runs well and has been there for me every time I needed it to blow the 140 inches we had this Winter. I should stop bitching right? My good friend down the road bought a new 2013 Deere 4320 cab last Fall. It has 25 hours on it. Last weekend he brought it by my place because he was unable to connect the 3rd function hoses to his new Frost-Bite grapple (nice product by the way). It has a super funky line setup (all Deere) that uses an electric solenoid at the rear of the tractor, then hoses going forward to the loader frame. It turns out he couldn't release line pressure. I turned the key on engine off then cycled the 3rd function buttons but still no clickety click of the solenoid at the rear, Turns out you must have the engine running to get power to that solenoid making it useless to try that method of removing hose pressure. Finally found the manual bleed off valve in the rear so we were able to connect the hoses. Also the door stays (stops if I may) are wimpy cables and not gas cylinders like the Botas have. He said one day he got home from work and one door laid on the ground after a wind storm, both hinges were broken clean off as was the flimsy cable. Dealer came and collected over-priced ($43K) machine and warrantied the hinges. He tells me this is the smallest USA tractor Deere makes, I wasn't too impressed with some of the machine although he likes it. Rear wheels welded not bolted so making fine adjustments to the width is not possible. The only width adjustment is done by swapping wheels left and right. Fred, always bitchin' about something.
So Fred, are you downgrading from hating your tractor to disliking your tractor? If so, we're going to need a new thread....
   / I Still Hate My Tractor II #158
If Fred gets a Deere we will have a new source of entertainment.
   / I Still Hate My Tractor II #159
We still get mail for my grandmother. Past away in 1967.
Mini Margaritaville Truck (A55853)
Mini...
2008 BMW 535xi AWD Sedan (A56859)
2008 BMW 535xi AWD...
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A56858)
2008 Ford F-550...
2014 Ford E-450 Super Duty Shuttle Bus (A56858)
2014 Ford E-450...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
