Worst factory headlight design
/ Worst factory headlight design #61
On a similar topic; why do GM pickups always have one headlight burned out.... ;)
/ Worst factory headlight design #62
That is the truth. I bet 60% of them around here do. My 05 ate bulbs and a few times I would be told it's out and I would go to change it and it was working....
/ Worst factory headlight design #63
I believe it, gm seems to have an issue with electrical connections. I have quite a few small quirks with both my suburban and my impala that are caused by bad contacts, either switches or plugs.
I've seen the same on GM, but some other brands too.
The liquid brine they use on the roads here is eating EVERYTHING. I recently talked with a guy who's buddy owns a heavy-truck shop north of here - they are seeing highway tractors not even a year old coming in..... not only are the lights on the back of the tractor out, the wiring is rotted out 4' up the harness !
I use some form of dielectric grease on every electrical connection, partly because of our "early-retirement" salt program here....
Rgds, D.
My GM pickup had a headlight burn out last year. I didn't think that was too bad for a 1994 vehicle. It was dead easy to replace too.
Time marches on...... the engineers who managed to sneak through those user-friendly designs are either fired, retired, or passed on. :thumbsdown:
Rgds, D.
/ Worst factory headlight design #68
why do GM pickups always have one headlight burned out.........Probably because the owner can't figure out how to install a new bulb.:laughing:
Or maybe the Fords end up in the scrap yard before their bulbs burn out , and the GM's and Rams are still running even with one bulb ten years later.............:laughing:
Stout Buckets XHD84-6 Brush Grapple Skid Steer Bucket (A65640)
Stout Buckets...
Frac Manifold S/A Trailer (A64194)
Frac Manifold S/A...
1989 Cheetah Chassis Corp 40ft. 36 Ton T/A Container Trailer (A64556)
1989 Cheetah...
CHANDLER 14' LITTER SPREADER (A64277)
CHANDLER 14'...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2019 BOBCAT E26 EXCAVATOR (A63276)
2019 BOBCAT E26...
