Disc Harrow JD Disc. Does anyone know what model this is and what its worth?
   / JD Disc. Does anyone know what model this is and what its worth? #11
My Monroe Tufline TH971820 cost me $2,428 delivered (no sales tax in Florida on ag equipment.) in February 2015. It weighs 915 pounds, 46 pounds per pan. It has 3" X 3" frame.
All the TL43 series are Cat 1/2, so they are engineered to be pulled by up to 100-horsepower tractors.
Equivalent Tufline TL439711820 weighs 1,189 pounds, 59 pounds per pan. It has 4" X 3" frame and likely thicker pans.
The TL4392020 is a bit wider, at 8', has all 9" spacing and weighs 1,318 pounds. I am sure it went for every bit of $3,000 new, likely more today.
TL4392020 does not have lever adjust of gang angles but at 1,318 pounds (66 pounds per pan) quick adjust may be superfluous.
Tufline recommends 45-horsepower minimum with 4-WD and from my experience with my 18/20", Tufline means MINIMUM. The tractor would have to be 6,500 pounds too.
Personally, I would consider TL4392020 a better value @ $2,500 than the W8 in Post #1 @ $500, if OP HAS ENOUGH TRACTOR.
   / JD Disc. Does anyone know what model this is and what its worth? #12
Just about anything would be a better deal than the W8. It'a an old, worn out disc with little to no adjustability.
I need to update my profile. I have a LS U5030 which is 55 hp. Its 5800 lbs before I had them add fluid to the rear tires. Would that be enough for the Tufline TL4392020? I know its 8' wide and like Jeff said, weighs about 1300 lbs.
   / JD Disc. Does anyone know what model this is and what its worth? #14
Tufline recommends 45-horsepower minimum; you have 55-horsepower plus a heavy frame tractor and loaded tires. In my opinion the Tufline TL4392020 and your LS 5030 would be an excellent match.
2016 Club Car Carryall 1500 4x4 Utility Cart (A55758)
2016 Club Car...
Takeuchi TB016 (A53317)
Takeuchi TB016...
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
2006 Caterpillar 315C L Hydraulic Excavator (A56857)
2006 Caterpillar...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
iDrive TDS-2010H...
