My First Tractor will be a Ventrac 4500Y.
   / My First Tractor will be a Ventrac 4500Y. #242
I spray the inside of my blower and chute with Silicone spray -- that helps. We have a gravel state road and the main problem comes with the gravel being picked up where they have plowed. The gravel even takes off the powder coat finish -- you end up with bare metal. We now have a Blacktop driveway and if that was all I had to do -- the blower would be a much happier camper ! :D :thumbsup:
Yes, I used silicone spray lubricant to treat the walls of the bucket, the face of the impeller, the auger, and the inside walls of the chute before setting out. I used up one partially full can (Solder Seal brand) that I had had for I don't know how long, and used part of another one of three cans that I had bought at the local Ace Hardware a few weeks ago. Those were the Ace house brand.
Fortunately, I do not have to deal with gravel.
BKB, I have come to the conclusion, as the result of the last two storms, that I could use a set of axle extensions and chains all the way around. I have the link to the site from which you purchased the V-bar garden-tractor chains, and I will be following up on that. I understand from what you have previously written that you ordered extra sets of cross-chains to achieve two-link spacing. Did you end up using any of the extra cross-chains that you ordered? Any particulars would be greatly appreciated.
Best,
JJM
   / My First Tractor will be a Ventrac 4500Y. #244
At what rpm?
At what rpm?
I conducted all operations at Wide Open Throttle.
Typically, the tach read 3400 rpm. The tach reading dropped to 3,000 rpm as I was simultaneously climbing the infamous S-Curved Hill and running the snow blower simultaneously. I adjusted the forward speed as I was climbing to keep the crankshaft rpms within that range.
   / My First Tractor will be a Ventrac 4500Y. #246
Thanks Sir John. That's the RPM I run at too.
Broomhilde Bats Clean-Up
It's time to change attachments...
And here are the results of Broomhilde's work....
And now it is time to rest.
   / My First Tractor will be a Ventrac 4500Y. #248
John, you can probably get by with just a set on the rears but I would not go with v-bars though. They will mark up your asphalt and concrete floors. I run a set of 2 link cross chains on the rear of mine when the snow starts to pile up or when it starts to get icy. I have v-bars for my bigger tractors and also a set of v-bars that will fit the steiner if I need them. All my plowing is gravel and grass with just cement aprons and cement floor that v-bars do damage when used. I had to get larger chains and remove some cross links to fit the Steiner. This is the best picture I have of mine. All of my chains I have bought at Tirechains.com.
Many thanks for your comments, DD. That is a nice-looking machine. The chains look very sturdy.
Best,
JJM
   / My First Tractor will be a Ventrac 4500Y. #250
John, how is that mower working for you? Any problems with grass in the radiator?
20ft Shipping Container (A57453)
20ft Shipping...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
2015 Chevrolet Silverado (A56858)
2015 Chevrolet...
Mini-Excavator Forks (New/Unused) (A59225)
Mini-Excavator...
2012 CAT Forklift (A55973)
2012 CAT Forklift...
2006 International 9400i (A55302)
2006 International...
