My First Tractor will be a Ventrac 4500Y.
   / My First Tractor will be a Ventrac 4500Y. #242
I spray the inside of my blower and chute with Silicone spray -- that helps. We have a gravel state road and the main problem comes with the gravel being picked up where they have plowed. The gravel even takes off the powder coat finish -- you end up with bare metal. We now have a Blacktop driveway and if that was all I had to do -- the blower would be a much happier camper ! :D :thumbsup:
Yes, I used silicone spray lubricant to treat the walls of the bucket, the face of the impeller, the auger, and the inside walls of the chute before setting out. I used up one partially full can (Solder Seal brand) that I had had for I don't know how long, and used part of another one of three cans that I had bought at the local Ace Hardware a few weeks ago. Those were the Ace house brand.
Fortunately, I do not have to deal with gravel.
BKB, I have come to the conclusion, as the result of the last two storms, that I could use a set of axle extensions and chains all the way around. I have the link to the site from which you purchased the V-bar garden-tractor chains, and I will be following up on that. I understand from what you have previously written that you ordered extra sets of cross-chains to achieve two-link spacing. Did you end up using any of the extra cross-chains that you ordered? Any particulars would be greatly appreciated.
Best,
JJM
   / My First Tractor will be a Ventrac 4500Y. #244
At what rpm?
At what rpm?
I conducted all operations at Wide Open Throttle.
Typically, the tach read 3400 rpm. The tach reading dropped to 3,000 rpm as I was simultaneously climbing the infamous S-Curved Hill and running the snow blower simultaneously. I adjusted the forward speed as I was climbing to keep the crankshaft rpms within that range.
   / My First Tractor will be a Ventrac 4500Y. #246
Thanks Sir John. That's the RPM I run at too.
Broomhilde Bats Clean-Up
It's time to change attachments...
And here are the results of Broomhilde's work....
And now it is time to rest.
   / My First Tractor will be a Ventrac 4500Y. #248
John, you can probably get by with just a set on the rears but I would not go with v-bars though. They will mark up your asphalt and concrete floors. I run a set of 2 link cross chains on the rear of mine when the snow starts to pile up or when it starts to get icy. I have v-bars for my bigger tractors and also a set of v-bars that will fit the steiner if I need them. All my plowing is gravel and grass with just cement aprons and cement floor that v-bars do damage when used. I had to get larger chains and remove some cross links to fit the Steiner. This is the best picture I have of mine. All of my chains I have bought at Tirechains.com.
Many thanks for your comments, DD. That is a nice-looking machine. The chains look very sturdy.
Best,
JJM
   / My First Tractor will be a Ventrac 4500Y. #250
John, how is that mower working for you? Any problems with grass in the radiator?
excavator trenching bucket- one bucket per lot (A56435)
excavator...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
2012 Kenworth T800 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2012 Kenworth T800...
Mini -Excavator Heavy Duty Rock Ripper (New/Unused) (A59225)
Mini -Excavator...
30in Forks and Frame Mini Skid Steer Attachment (A56857)
30in Forks and...
2004 GMC Sierra 3500 Pickup Truck (A55973)
2004 GMC Sierra...
