john deere quick attach to skid steer attach
/ john deere quick attach to skid steer attach #1
jnewhard
Slatington, PA
John Deere 2032R
Hey guys i have a 2032r with a H130 loader. i was wondering if its worth it to get the skid steer adaptor and how much it will lower my lifting capacity?
/ john deere quick attach to skid steer attach #2
Welcome to TBN! Congrats on your new tractor
i guess a bigger question might be what attachments are you wanting to use on
your loader that you want to change over to SS style for?
/ john deere quick attach to skid steer attach #3
The carrier itself does not add a lot of weight, the downside can be the limited # of ss attachments that are quite a bit heavier than your current bucket, etc. Lighter ss style attachments do exist just not as many choices as full blown skidsteer pieces. IMO you are better off keeping the std Deere quick attach system, you can buy the upper loops and bottom studs from numerous aftermarket folks to weld on to different att to expand your attachment choices. I personally believe that ss carriers are best suited (if actually desired over the global ag connection) for large frame compacts and utility tractors.
/ john deere quick attach to skid steer attach #4
jnewhard
:welcome: to TBN
What attachments might you be considering (other than a bucket or forks) ?
well my john deere dealer wants $900-$1000 for a set of pallet forks. and i can find pallet forks for a skid steer a lot cheaper and if i switch to SS then i can use different buckets that my parents have laying around.
/ john deere quick attach to skid steer attach #6
I bought an adaptor to go from Deere QA to skid steer from an Amish shop in Millersburg, OH. Beautifully built and fits both my 89hp 5520 as well as 790. Whatever small amount of weight it adds, it's worth it. I should have done it years ago.
/ john deere quick attach to skid steer attach #7
In my opinion, a quick attach adapter would hinder your lift capacity and be counterproductive on that small tractor.
JDQA attachments are more common now than in the past, but they are quite a bit more if you buy them from a JD dealer.
Here are the perfect forks for your tractor: Construction Attachments 42" John Deere, John Deer, Quick Attach JD, Compact Pallet Forks CAL-1PFCMPSM42
220 pounds with a rating of 1,800 pounds
Free shipping to a staffed commercial business or to the freight terminal in Bethlehem.
Travis
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 PETERBILT 388 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2021 PETERBILT 388...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
John Deere 400 (A64119)
John Deere 400...
