Interesting Failure Today
/ Interesting Failure Today #1
DT86
Elite Member
VA
Kubota
We've had our share of snow in the past three weeks, it will warm up enough to make a muddy mess, rain then refreeze and snow some more. I've honestly lost count of how much we've had over all. Yesterday it got up in the 50's melting most of what snow was left and causing some minor flooding. Today we had some rain, freezing rain and a light flurries by lunch time.
This afternoon I went to start the RTV to let it warm up while I scraped the 1/4" of ice off the windshield. After the glow plugs did their thing it started right up, ran rough for a few seconds and died. Hit glow plugs again and gave it a little throttle while cranking. Started fine but again wouldn't idle well after I let off the throttle, however it was still running. The slower than normal idle made me think it was trying to gel up.
Get out to go find my Diesel 911 then instantly smell burning rubber. Turn the switch off and the engine continued to run. I raise the dump bed to see what's going on and the fan belt is smoking! Try the key again and it still won't shut off.
I am now realizing that I've never bothered to look at the shut off solenoid to see how it works and if it can be manually manipulated. I decided it will be quicker to pull the air filter and stuff my glove in the intake hose.
With the metal clasps undone wouldn't you know the d@*n cover is frozen onto the air filter housing! I step back and give it a love tap with my size 12, cover comes off, yank the filters and stuff a glove in the intake. It dies in half a second.
I step around to the other side with smoke still coming from the belt, just in time to see and hear it snap in half. While it seemed like a 10 minute ordeal it probably lasted less than a minute from start up to belt failure.
Now how did this happen?
Remember the flood waters from yesterday? I had to drive through some standing water when I went to check cows just before dark. Not a lot, maybe 2-3" at most. That combined with what water drips between the bed and roll bar had formed a nice glaze of ice over the front of the motor. This had frozen the belt solid to the pulley which caused enough drag to make it idle rough, smoke the belt and freeze the fuel shut off.
As far as I can remember the belt is the original with just shy of 1100 hours on it. It's probably due one anyway.
Now that the belt is gone both the fan and alternator turn free by hand.
Anyone else ever have a similar situation or am I the only one with such luck?
:rolleyes:
Meant to say it is a Kubota RTV 900.
Trying to add pics but the app keeps freezing. :mad:
/ Interesting Failure Today #3
Never had that happen but can certainly see how it could if stored outdoors..Glad that no lasting damage was done.
/ Interesting Failure Today #4
Good save! Things could of got outa hand.
/ Interesting Failure Today #5
Quick thinking, many people would not have been able to figure out how to shut it down. thinking fuel and air you made the right move. May next belt change be less exciting.
/ Interesting Failure Today #6
I have always wondered if one could suffocate a diesel like that.
/ Interesting Failure Today #8
Meant to say it is a kubota RTV 900.
Must have gotten the phone wet too ! :laughing:
/ Interesting Failure Today #9
A dumb question most likely ... but ... why wouldn't the engine turn off with the key? How does the belt issue allow the engine to start but not shut off?
MoKelly
/ Interesting Failure Today #10
He said that the fuel shutoff solenoid was iced up, that will keep it from moving enough to shut the fuel off.
Aaron Z
/ Interesting Failure Today #11
Quick thinking. I never thought of how to stop a diesel if the key/stop solenoid failed. Good to know, hope I never have to remember!! I've got a diesel pickup, tractor and RTV 1140.
/ Interesting Failure Today #12
Now, regarding a diesel you can't shut off as it relates to the classic hydro vs manual transmission debate ( on tractors):
Can most of the hydro tractors stall themselves out if in high range and you stomp the pedal?
I'm pretty sure I could stall my manual tractor if in high gear and I drop the clutch.
/ Interesting Failure Today #13
Reminds of a time when I was young and worked in a yard that piggy backed semi tractors to transport across the country. I drove one up to the staging area and it wouldn't shut off. I seen a button that said "emergency shut off" so I hit it and sure enough the engine stopped. Boy did I catch h#ll for that. The older guy I worked with told me to never do that again and if the engine doesn't stop just put it in the highest gear and drop the clutch. I won't forget that bit of advise soon.
/ Interesting Failure Today #15
Yes, with my HST tractor, it can be stalled by putting too much load on it for the gear range chosen. If for some reason it would not stop when key turned off, I would reduce RPMs to idle, put in high gear, drop FEL and box blade to ground, stomp on HST pedal. I can't imagine a situation where it would not turn off. Cut off solenoid is enclosed and not subject to freezing up.
With an RTV...I DUNNO how you would quickly put a load on it...chaining it to a post in high gear and trying to move it would likely do it...haven't tried...but not an instant fix.
/ Interesting Failure Today #16
Usually it's easy enough to stuff something over the air breather / snorkel if you can get to it. My luck I wouldn't have anything around to stuff in, so I'd probably have to peel off a shirt.
Well I'm back from town with the new belt, stupid thing was 20 some dollars.
Thanks guys, I must admit I owe my knowledge of suffocating a engine to YouTube videos of run away diesels, including the one posted previously.
/ Interesting Failure Today #20
On my tractor with a key solenoid shut off I notices a lever safety wired shut on the side of my injector pump.
Curious guy I am, I cut that wire free and actuated the lever with engine running. Instant shut off!
So I attached a nice thin flexible line to that lever and routed it to the cab with a small red knob attached.
Home brew emergency shut off!
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2002 Pace American of Texas Trailer, VIN # 47ZA528212X020330 (A61572)
2002 Pace American...
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
New/Unused 72inch Quick Attach Rock Grapple Bucket (A65583)
New/Unused 72inch...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
