Another cold weather not starting thread.
/ Another cold weather not starting thread. #1
rasorbackq
Springfield Nova Scotia Canada
Branson 4720
After reading all 9 pages of TSO post ref Cold weather not starting tractor I can say I have the same problem as him. My tractor does not like to start this winter when its cold Say -15 C. As soon as the sun hits it it will start. So I figure its ice somewhere in the system.
I'm not aware if I can buy #1 ,2,or 3 Diesel . I get what comes out of the pump. same fuel in our VW and it runs all winter.
Whats the census..... can we add methyl hydrate to diesel?
should we add something?
/ Another cold weather not starting thread. #2
I would believe you have a glow plug problem. The sun does have heat again at this time of year.
Your light will say the glow plugs are on even if they are not check and see if they are heating up
your repair manual should tell you how to test them, if you don't have a repair manual you need to get one.
even one glow plug not working will cause an 8 cyl. diesel not to start good, two out and my F250 will not start at 0 f
/ Another cold weather not starting thread. #3
Regarding #1, #2 etc. diesel fuel, here in our neck of the woods we get what's at the pump. In the summer it's thicker but has higher energy, while in the winter it's thinner but has less heat value. The refiners here (you know who the big one is) switch over to winter diesel during the fall and back to summer grade in the spring. The trick is to make sure you get fuel for winter use after the local station has received at least one (I prefer two) bulk deliveries of winter fuel. I re-fuel with jerry cans and I try to save one can of winter grade over the summer to start off the fall. I also try to buy at least my first batch of winter diesel from a station that I know pumps large volumes of diesel (like a truck stop). If I'm caught with summer diesel in the tank in the fall, I cut with kerosene. I also use Howes Lubricator diesel treat, just in case.
I don't have a manual for the tractor . I turn the key the dash light indicates the plugs are on After 5-10 secs the light goes off and a clicking noise continues. It turns over great with no smoke. wait til the sun hits the tractor to melt off the frost and it will start ever time. Still talking -15 C
/ Another cold weather not starting thread. #5
Does it fire but not run? If so, it could be ice or gel. If it doesn't fire, it's probably the glow plugs.
Your tractor's fuel filter is probably more in the open than the one on your VW. If your VW is like our TDI, its fuel filter is nestled up next to the engine block.
You could get some chemical hand warmers (you know: the kind where you activate them by bending or breaking something so the chemicals get together). Just attach one of these to your tractor's fuel filter and wrap it in place with banding. This would take care of any gelling or icing.
Ralph
/ Another cold weather not starting thread. #6
Are the glow plugs set up in series on those..?? I know my old '91 Ford's 7.3's were. The first inline may be working, and the next one not,, or any of the rest, and would not start. Tested them, and replaced what was bad, and started like it was in July.
Ralph
No fire just turns over
/ Another cold weather not starting thread. #8
Diesel fuel pumps and alcohol do not work well together. Or so I have read. Add the proper additive that does not contain alcohol.
Use heat gun on the places you feel there might be gelling etc. do this before the sun hits it. Might indicate where the problem lies.
For diesel Fuel grade I kinda think that what's at the pump is your choice unless you buy bulk from a distributor.
/ Another cold weather not starting thread. #9
Unless there's water in your fuel the only place you'll need to warm up is your fuel filter. If the fuel is jelling add some kerosene to the tank ( NO alcohol). And what Egon said.
/ Another cold weather not starting thread. #11
You can add a lt. or a gal. there are no ill effects kerosene is just more refined so it has a lower flash point and won't jell as easily. Mixing it may be difficult with the existing in the tank unless the machine is running then the diesel that's circulating should warm what's in the tank and mix it up. If necessary you could remove the filter and fill it with kerosene to help get started.
/ Another cold weather not starting thread. #12
Could be dumb luck, but I use Power Service anti-gel additive, about 1 oz. per gallon (or whatever they say to use, it's been awhile) and have never had any issues, and it gets cold here. 8 degrees F here this morning. I burn home heating oil year round. The delivery drivers all say that the dyed fuel is the same as what is sold for off-highway vehicle use, direct from the fuel depot.
/ Another cold weather not starting thread. #13
I thought of doing the 5 gallon can hold over during the summer. Does the fuel hold up just fine, or does it go stale over the summer?
Thanks, -Daron
/ Another cold weather not starting thread. #15
One thing I don't ever see mentioned here is that most tractors have a way to extend the run time of the glow plugs which in colder temps is sometimes needed for a cold start. On most of the newer tractors you turn the key backwards and hold it to enable the glow plugs to work for an extended period of time then start your tractor.
Varmint...... You say its cold in Maryland so you burn home heating oil year round ...... Where in your house or tractor???::cool2:
/ Another cold weather not starting thread. #18
Rasorbackq, since we're talking about tractor fuel, in a tractor.
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
2022 CATERPILLAR 299D3 XE SKID STEER (A64279)
2022 CATERPILLAR...
2020 TIGERCAT 234B LOG LOADER (A64276)
2020 TIGERCAT 234B...
2020 HONDA PIONEER 1000 RTV (A64280)
2020 HONDA PIONEER...
2016 Nissan Titan XD 4x4 Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
UNUSED IRANCH IRTPL 10000 LB TWO POST LIFT (A64281)
UNUSED IRANCH...
