Diverter valve now in stock at Surplus
   / Diverter valve now in stock at Surplus #2
12 VDC 13.2 GPM SAE 8 SOLENOID DOUBLE SELECTOR VALVE
Look for it in Selector valves section.
These valves can also be stacked.
That is a good price on those.. Very similar to the ones Fasse makes. They do not have the stacking tie rod kits, but it does come with the Hirschman connector and 2 O rings for stacking. They do not have any application data sheets. But I "assume".. that the fluid flow would be in the left, out the right and the energized coil flow would come out of the face.. Their tech did not know.
   / Diverter valve now in stock at Surplus #3
It'd be really weird if that wasn't the case - no point making them stackable otherwise. I'm glad to see Surplus has them back in stock, still thinking about a couple more for my projects... Steve
You will notice that the top face and one of the side face of the valve has an indented side which is for the o-ring.
They can be stacked.
   / Diverter valve now in stock at Surplus #5
I don't know why they don't have the stacking tie rod kits, but he said you would just have to source that yourself locally. I wonder if the fasse valve stacking tie rod kits would work on these?
   / Diverter valve now in stock at Surplus #6
I am (forever) in the planning stages to add remote hydraulics to my FEL. I was looking at this solenoid valve
SAE 8 6 GPM DOUBLE SELECTOR VALVE 12 VDC P15544-2
Do you see advantages in the new product you posted about compared to Item no. 9-5117-A aside from higher flow capacity (which I won't need) and stackability?
   / Diverter valve now in stock at Surplus #7
I don't. Provided your flow rate is 6gpm or less and you don't want to do any valve stacking.
   / Diverter valve now in stock at Surplus #9
Thanks James. The pump on my tractor is rated for 7.8 gpm (as I recall) but I can't imagine needing to stack solenoid selector valves for any application I might have.
   / Diverter valve now in stock at Surplus #10
JJ, my plan is to add a control valve in the cab, run a set of hydraulic lines from that valve out along the boom, and end those lines in a solenoid selector valve so I can have two additional functions at FEL boom when needed.
I was actually thinking that for my intended applications, having slightly restricted flow to slow down the piston action might be beneficial. Aside from slowing the pistons would using a 6 gpm selector valve cause any problems?
More background:
The uses for the remote hydraulics will (might) include single action cylinders to angle a snow plow, two small double action pistons to open and close wings on the plow, log grapple that can be rotated hydraulically (I envision home made, with a double action piston, or two single action pistons on a cam to rotate the grapple 180 degrees give or take), double action pistons to raise and lower a bucket / root grapple.
2010 Cadillac CTS Performance Sedan (A48082)
2010 Cadillac CTS...
2002 Ford F-150 Pickup Truck (A50860)
2002 Ford F-150...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A51039)
2014 Doyle Dry...
UNUSED Stainless Steel Sink (A50860)
UNUSED Stainless...
71067 (A49346)
71067 (A49346)
Vacuworx Vacuum Lifter Pad (A50860)
Vacuworx Vacuum...
