Is it possible to move the pump gear a tooth with the pump off?
   / Is it possible to move the pump gear a tooth with the pump off? #1
jrchafin
Mahinda 7520
I have a Mahindra 7520. I had to remove the fuel injection pump to fix a leaking gasket. This pump attaches to the pump gear with a key and a tapered shaft, so it is easy to re-assemble, as long as you don't spin the motor or the pump when they are separated. At least, that's what I thought.
When I reassembled it, it will hardly run, sputtering and coughing, spewing gray smoke. It's like the timing is off. The timing marks on the injection pump and the engine housing are aligned. In fact, in that position it won't run at all. When I loosen the pump and spin it clockwise, advancing the timing slightly, it will run some, but barely.
So, given it is a woodruff key reassembly, and I am positive the key went into the pump gear correctly (I used a mirror), the only way the timing could be off is if the pump gear itself somehow skipped a tooth. Maybe there was enough play when the pump is off that the gear could move to the side, disengaging from it's mating gear, and then re-align off one tooth. Is that possible?
shameless bump.
   / Is it possible to move the pump gear a tooth with the pump off? #3
No, not likely, but easy to reassemble one tooth in error. Have had it happen too many times, even once on a hand built in the lab prototype.
   / Is it possible to move the pump gear a tooth with the pump off? #4
Pardon, are you for sure talking about the Mahindra 7520? ... Or JD
2009 INTERNATIONAL 9200I TANDEM AXLE WRECKER (A58018)
2009 INTERNATIONAL...
2025 Wolverine SP-15-84W 84in Snow Pusher Skid Steer Attachment (A55973)
2025 Wolverine...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
Cushman Electric Cart (A55851)
Cushman Electric...
