fitter1
I've been thinking of using the boom on my PHD with a logging tong. But that pulley setup sure is nice.
I have never used tongs. Does a more expensive set work better than the cheap ones. I bought a cheap cant hook from NT one time. No matter what I did I couldn't get it to work. I finally heaved it into a burn pile after getting smacked with it. I went and bought a good one and no problems. So I didn't know if the same holds true for tongs.
I use mine to lift big logs onto the splitter or move them around. Picks up rocks too. And with my boom pole to carry/drag wood out of the forest. View attachment 409196
Buggs67,
I was thinking about doing something like that. Wondered what it is like on bumpy ground having several hundred pounds suspended and flopping around back there?
I once made an impromptu water delivery run for the local fire department fighting a brush fire where their trucks couldn't go. Unfortunately, my post hole digger was on the back at the time and I had to go slower to keep it from banging around too much. Several hundred pounds back there might have been a real handful.
Thanks Gordon. I was able to get a pretty good start on mine yesterday. I have a 3" angle across the bottom that my drawbar will bolt horizontally too (instead of vertical like yours ) so I can put a 1 7/8" ball where you have the hook. My plan is to push my log arch over the log, unhook the log arch from the ball, hook into the log with the skidding tongs, pull the log into the position to be lifted with the arch, secure the log to the arch, and tow it out of the woods.Here is the finished A-Frame with the TL ears welded on
