Connector for adding beacon warning light?
/ Connector for adding beacon warning light? #1
Threepoint
No. VA
Kubota B2150HST w/ LA350 loader, Kubota GF1800 HST, Kioti CK3510SE HST w/ KL4030 loader, Kioti NX4510HST/cab w/ KL6010 loader
I'm planning to add an amber beacon LED warning light to my Kioti cab to augment the OEM flashers when plowing snow and grading. Probably this one: Amazon.com: HQRP 12V DC Emergency Amber LED Strobe Mini Light Beacon Flexible Pipe Mount / Low Profile, Tow / Plow Escort Safety for Truck Car Auto plus HQRP Coaster: Automotive My NX4510 has a dedicated molded connector for a beacon just above the bracket for the SMV sign, 12v power when the running lights are on. I've attached a couple of pics taken at different angles. Anyone happen to know what matching connector I'd need to make this a plug-and-play install?
/ Connector for adding beacon warning light? #2
I've seen that style of connectors in most brands of Japanese autos. Maybe take a trip to the junkyard? Have you checked with the dealer?
/ Connector for adding beacon warning light? #3
Just cut it off and put a weather pack on it.
/ Connector for adding beacon warning light? #5
/ Connector for adding beacon warning light? #6
Thanks, Everyone, for the replies. Good ideas. I did check with a dealer, but to their knowledge Kioti doesn't offer a kit for this, and they didn't have a cross-reference for a matching connector. Their customers who want a beacon usually just plug into the 12v accessory socket in the cab.
If I can track down the right connector, I'll post the info. Otherwise will snip off the OEM and go with Weather Pack or similar.
/ Connector for adding beacon warning light? #8
I'm glad you posted the info of when the connector had power, i figured it had to have a switch installed with the light kit.
/ Connector for adding beacon warning light? #9
Did you ever get a beacon installed, Just curios how it turned out? Also does the beacon run anytime the lights are turned on?
Yep, it turned out well. I fabbed a simple mounting plate for attaching the beacon to the bracket that originally held the SMV sign, and moved the sign to the opposite side of the tractor. For the electrical connection to the dedicated harness, I ended up just cutting off the Kioti factory connector and used crimp-on bullet connectors that I happened to have, followed by wire loom and electrical tape.
The beacon is on only when the running lights are on. So the headlights, work lights and factory warning flashers can be used without the beacon, if desired. I'll try to post a pic tomorrow, if you like. Very happy with the setup for only $40 all in.
/ Connector for adding beacon warning light? #11
Ok yeah a pic or two would be great, going to fix up a mount for mine over the next few days.
CB, I've attached a couple of pics of how I mounted my HQRP beacon on my NX-series, in case you or anyone else want to do it this way to use the nifty Kioti factory beacon harness. Don't know if the beacon is the same one you bought. I wanted a post-mount style, since the magnetic mount-style doesn't work too well on polymer roofs. :) Here's a link on Amazon, although I ordered direct from HQRP on eBay for a little less. Amazon.com: HQRP 12V DC Emergency Amber LED Strobe Mini Light Beacon Flexible Pipe Mount / Low Profile, Tow / Plow Escort Safety for Truck Car Auto plus HQRP Coaster: Automotive
The mounting plate is 3/16" mild steel plate that I already had in the shop, cut to 2-3/4" x 7-1/4 with a portaband. It attaches using the two existing bolt holes in the factory bracket that is welded to the cab's left rear window post to hold the SMV sign, so no modification is necessary. However, the factory bracket protrudes at a compound angle, so the mounting plate must be leveled front-to-back before marking it for drilling (pic 2). Otherwise the beacon's mounting post won't be plumb. Even then, it was necessary to make a slight bend adjustment to the bracket that comes attached to the beacon's mounting post in order to bring it plumb side-to-side.
I mounted the beacon as high as I could without running into clearance issues at the doors of my tractor garage and barn. It's still visible from 360 degrees around the tractor, but a bit less well from the front than from the sides or back. If clearance weren't an issue, I would just flip my mounting plate bottom-up to raise the beacon another 4" or so.
The rattle-can Kubota factory gray that I had on hand is a bit lighter than the Kioti gray, but it was close enough. :)
BTW, when I moved the SMV sign to the bracket on the opposite side, I had to realign the sign to keep it vertical because the angle of the right-side bracket is just the reverse of the left-side. Rather than make shims, I just redrilled the top hole in the face of the sign 5/8" farther to the left and adjusted it that way.
/ Connector for adding beacon warning light? #13
I have a PSE 550 rotator , I thought about ordering a new strobe light but figured I use this one sense it didn't cost anything.
That'll sure do the job. The new LED beacons are pretty slick, though. No moving parts. Under the amber lens there's just a cylinder covered with white LEDs that are perfectly synchronized so that the flashes march around the surface, simulating a 360-degree rotating beacon. With the lens on, it's hard to believe nothing is actually turning. A micro-switch lets you change the function to fixed strobe, either rapid or slow flash. The beacon is on a flexible stalk that plugs into the post/pipe mount. Loosening the wing nut lets you lift it off, leaving the mount and harness undisturbed. I figure I'll need that feature the first time I drive into the woods. :)
/ Connector for adding beacon warning light? #16
Tested my plug today, and it has power in both positions of the light switch, first position which is position lights and second which is position lights and headlights. So I guess I will need to install a separate switch to control the beacon, really don't need or want it flashing just because I have the headlights on.
/ Connector for adding beacon warning light? #17
Ended up making this out of stuff lying around the shop.
2014 PETERBILT 389 6X4 T/A GLIDER SLEEPER TRUCK TRACTOR (A68363)
2014 PETERBILT 389...
CHEVROLET C-40 FLATBED TRUCK (A63291)
CHEVROLET C-40...
(INOP) LAYMOR SM300 RIDE-ON SWEEPER (A65054)
(INOP) LAYMOR...
Ez-Go Electric 3-Wheel Golf Cart (A64912)
Ez-Go Electric...
DYNAPAC  CP271 PNEUMATIC ROLLER (A67714)
DYNAPAC CP271...
New Quick Attach Hay Spear (A65563)
New Quick Attach...
