M96
No, but they look very capable.
/ M96
They start at $53,000. I'm wondering how its used compared to regular machines?
I almost bought one. It's heavier than you would think for a Kubota, has strong castings and seems to be suitable as a utility tractor with a loader, a hay baler and medium sized tillage tractor. Seems like it would do well on a dairy farm or dairy with lots of hay and limited tillage application.
/ M96
But why the big front wheels?
As I recall, the rear were 18.4-34 and the front 12.4-24. That's not big but rather an accepted tire pattern for that HP tractor. I suppose factory options you give you a larger tire size but it would still have to be somewhat similar to the sizes I mentioned. Do you see a different size tire/wheel?
I have a M126. Looked at M96, M110 and decided to go bigger. The M96 has a small displacement engine. Once you jump to the 126, you get a 6.1L diesel. M96 is almost as big and heavy and only 3.8L.
Nice tractor though.
Pictures? I love to see the big Kubotas.
We have three M96 mudders on the lot right now. I'll try to take some pics tomorrow. I'm working on a M108S and a M105X right now. Oh yeah and a M9540.
<img src="http://www.tractorbynet.com/forums/files/kubota-owning-operating/410213-m96-forumrunner_20150204_202438-png"/>
<img src="http://www.tractorbynet.com/forums/files/kubota-owning-operating/410214-m96-forumrunner_20150204_202456-png"/>
Nice. Beast Mode.
The little RTV500 looks out of place. We have a bunch of M135X's too.
Brian
Where's the lot... aren't you mostly mobile?
I see a RTV in my future... seems used really hold their value... maybe I should start a new thread asking for you advice on RTV buying and if the new X series is the way to go?
I ended up going to work for Big Valley Tractor in Stockton.
Brian
Do you still have your rig with mobile shop? The pictures were awesome that way you had it set up.
I still have it for now. It's pretty bare with my toolbox out of it and a lot of the tools. I'm probably going to finish pulling the equipment out and sell it this spring.
Brian
Did you buy the Freightliner for towing?
The reason I ask is because several times I have mentioned you to friends that needed a mobile mechanic... out in the Alhambra Valley and Livermore...
Either way... glad you found a set up that makes sense for you... lots of overhead going mobile...
So how many of the big Kubota M tractors do you see in a typical month?
Do the bigger Kubotas compare well with other offerings... I looked at an M59 briefly and then decided it was simply too big and I would have to hire someone to move it if needed.
Oh wow! Nice! Tire pressure on the front?
That what 2 1,000lb silage bales and a 500lb bale spear do. Tires are low on pressure, too.
Here's the other 9540
2018 Ram 1500 Reefer Meal Delivery Truck (A61573)
2018 Ram 1500...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
2014 John Deere 1025R (A64126)
2014 John Deere...
2017 Versatile 260 (A64126)
2017 Versatile 260...
