Help!! A770 unknown failure message
/ Help!! A770 unknown failure message #1
ColonelWife29
Ct
Bobcat A770
I have a active warning message stating this code E523601-00 unknown failure. I can't find what it means!!
/ Help!! A770 unknown failure message #2
Thats very common , the thermal uplink coupler has over heated and rubbed against the oscilator . To correct this , sit on the tractor and blow the horn 7 times with your right foot on the clutch .
Now being serious more info as to the tractor type and more specific as to what it is , or not doing
It's a 2013 Bobcat A770.
/ Help!! A770 unknown failure message #4
Try disconnecting the battery cable from the positive side , keep it off for a couple minutes and then re start the machine .
/ Help!! A770 unknown failure message #5
Does code occur while engine is running or right after turning on wihtout starting engine?
/ Help!! A770 unknown failure message #6
In case it may help, E523601-00 is the service code for: Exhaust gas temperature sensor fault.
CRAFCO MAGNUM SPRAY INJECTION PATCHER (A59823)
CRAFCO MAGNUM...
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
2010 John Deere 4720 (A60462)
2010 John Deere...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
JOHN DEERE 772GP MOTOR GRADER (A58214)
JOHN DEERE 772GP...
