Driveway Gate Install
/ Driveway Gate Install #1
troutsqueezer
Pilot Hill, CA.
Kubota B21
I'll tell ya what, try to get someone to build you a gate so you can take it home and install it yourself? Not so easy. They all want to install it for you 'cause there's money to made there. If you tell them you want to do the work yourself then it's "see ya later". We had a hard time finding someone around these parts who would just build us a gate but eventually we got there. although it took three months. Now I'm in the process of installing it. It gives me something to do for a few hours every morning. Life is good. I know you guys like threads with pictures in them so thats what this is.
Here's the gate when I brought it home. I figured standing it up and leaning the gates together was the best way to haul them. Worked ever so well.
First order of business was to dig the holes. Rented a two-man post hole digger and had them dug in no time. I am using outriggers to keep the posts from leaning being as this is a dual swing and prone to misalignment after a period of time.
Twenty bags of concrete later.
Next up is welding the hinges on. These gates are very heavy and the hinges are robust.
Had to flap disk the powder coating away so as not to contaminate the welding.
Welding is a little rusty but it did not come out too bad.
Will post more pics as I progress. Thanks for looking!
/ Driveway Gate Install #2
Looks good! I did one about a year ago. I found that Ameristar would sell to me directly, but the cost for the install itself turned out to be minimal, especially with the discount the contractor got buying the gate VS me going direct. Here's a link to the thread, pics of the finished product are on the last page: http://www.tractorbynet.com/forums/projects/290381-driveway-gate-how-questions-challenge.html
Are you going to automate it? Looks like you have a solar setup there. How big are the panels? Looks pretty good sized.
/ Driveway Gate Install #3
Nice looking gate and great job. Man, those two gate posts aren't about to go anywhere. Also enjoy looking at the background scenery - nice country.
/ Driveway Gate Install #4
Thanks for those wonderful pictures - it's looking good. Can't wait to see the gates installed. :thumbsup:
/ Driveway Gate Install #5
One of the reasons that everyone that builds gates likes to do the install is that we'd normally match the hinge side of the gate to the post and weld the hinges on prior to PC. Far easier to set the post to a certain depth/distance apart than jockeying everything into place to get the hinges tacked on.
Since these gates just lift on and off the hinges, I'd weld a threaded insert into the posts above one of the gate hinge levels so a block could be bolted above it and only accessed when it was full open, to keep someone with a floor jack from getting in (or two guys with grease guns, for that matter).
/ Driveway Gate Install #6
Everything looks really nice! Love the gate design.
If you ever want to add more fence you can buy the materials to match from king metals.
How deep are the post holes? At first glance they seem a little shallow but it's hard to tell. I've seen way too many posts move after installing so I try to go 4-5 ft deep minimum.
Thanks for sharing.
In my case, digging the holes was a hit or miss proposition, mostly miss. I drove a pipe into the ground up and down the driveway to find a spot where I could dig and have the best chance of not hitting big rocks. In other words, getting the posts into a precise position with regard to hinge height likely would not have worked because I didn't know how deep the posts were going to be nor did I know the slope of the driveway until I had the holes dug. My probing before digging paid off, both holes are three feet deep.
I plan on welding a 1/4" thick piece of steel to the posts above the top hinges that will stop anyone from lifting the gate. The welds will be on the sides so that I can access them with an angle grinder if I ever need to pull the gate off.
Of course, if anyone really wants in, this gate won't stop them. It's only meant as a deterrent. If the gate is open when I know it should not be, it's time to holster the weapon and go on recon. :eek:
Thanks for sharing.
Thanks, roadhunter. As I mentioned in the last post, the holes are three feet. I'm hoping with the outriggers they won't move too far. I probably won't add any more fence, when I am done with this, I'm on to something else due to a short attention span.
/ Driveway Gate Install #9
Guess I will need to call ahead when I come to visit ;-)
No more riffraff coming up the drive... you sure do have a nice spot there...
I remember that post, in fact, I commented in it, a worthless comment but then, most of mine are. I was thinking of used brick for columns but in looking at your pictures, those columns look very nice. Do they have mortar in them or are they just placed together?
/ Driveway Gate Install #11
You do very nice work there Troutsqueezer.
/ Driveway Gate Install #12
That's a big project, and it looks good. Nice.
The views are sweet too.
My call box will store 32 number codes in memory, each with 5 digits. You can probably guess one of them with just a few tries.
As for riffraff, I used to be way out in the country here in my humble little house. Now, suburbia is sneaking in. Mostly rich people who build mansions and never come outside. Maybe they'll see my gate and think someone with some money lives up there.
Thanks for the comments, guys.
/ Driveway Gate Install #14
Yes enjoying thread also .
Looks real nice , like the surrounding scenery . Thanks for shareing your experience , pics , by takeing time out and posting thread ! :thumbsup:
/ Driveway Gate Install #15
They are dry stacked blocks, but I did use adhesive so they are bonded together (at 7' i didn't want to risk someone hitting them and having it fall on them). They're from a kit and surprisingly cheap and easy to diy.
You've got a great view. Any special reason for the gates, or just general privacy? Weirdly I've had a few people walk around mine (saw them on the security camera at night, no idea what they were doing).
/ Driveway Gate Install #16
I see you're in California, a frost free area I hope?
The reason for the gates is that several homes not far from us have been robbed lately. Ive got several game cams set up but those won't deter anybody. At least the gates will keep someone from casing the joint. I am at the end of a long gravel road and at the top of a hill so it's pretty private.
I priced out concrete blocks at Lowes today, about the same size as yours. Two five foot columns came out to almost $500. Thats at $2.88 apiece, 120 blocks. I do like how easy it would be.
/ Driveway Gate Install #20
Good work so far, but I think I see a problem already. We had a thread a couple of weeks ago where a guy could not keep his gates from hitting the ground. His problem was the surrounding terrain/drive was not level. He ended up having to fudge the hinges out of plumb a little bit to make it work out, not the best situation.
It looks like in the picture above the gates will be located on a part of the drive that is sloped. Have you thought how this is going to work out? Can you grade the driveway flat in that area?
If you open the gates toward the polaris, they will be really high in the air when they are open(might not be a problem really). If you open them toward the wheelbarrow, you will probably have the cut the driveway down up toward the wheelbarrow area.
2201SFL (A64553)
2201SFL (A64553)
ITS 16 Pipe Squeezer (A68842)
ITS 16 Pipe...
2019 Peterbilt 520 T/A EZ-Pack 40Yd Front Loader Garbage Truck (A66736)
2019 Peterbilt 520...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2022 WIFO WBGS Hydraulic Bale Grabber Skid Steer Attachment (A66734)
2022 WIFO WBGS...
2006 Freightliner M2 112 T/A Wet Kit Day Cab Truck Tractor (A66736)
2006 Freightliner...
