Ford New Holland 2120 Shuttle Shifter moves, but remains in forward only....?
   / Ford New Holland 2120 Shuttle Shifter moves, but remains in forward only....? #1
srshaw3
Member
Gilsum, NH
Ford 2120 & John Deere 450B
My tractor has decided to not change from forward to reverse, regardless of where the shuttle shifter is moved. The shifting was working fine while moving snow with the loader and then no more reverse.....
In the past when starting the tractor, it would always be in neutral regardless of where the shifter lever was, so I presumed it was a safety measure to have an electric/electronic switch to neutral. Now it is in forward at all times.... Maybe just some snow somewhere?
   / Ford New Holland 2120 Shuttle Shifter moves, but remains in forward only....? #2
My guess would be a loose or disconnected linkage.
Thanks, first thing is to pull the steering gear cover I guess :)
   / Ford New Holland 2120 Shuttle Shifter moves, but remains in forward only....? #4
That's where I would start. My ignition was loose on my 1920. Not a lot of room when u take the cover off but u might be able to see where it's loose
So I invested in a real manual for the Shuttle Shifter and found that a cable was disconnected, apparently related to the Lube Cutoff Valve. I was hopeful it was the issue. I reconnected it, using a bolt, as the clevis pin is lost. Perhaps it is simply an adjustment now, as the location is sloted and page 8 of the manual shows an adjustment. If that is the case, I might bring the tractor in for proper service, as well as setting that adjustment.
2008 Dodge Ram 1500 Single Cab Pickup Truck (A55973)
2008 Dodge Ram...
2015 Dodge Journey SXT Van (A56859)
2015 Dodge Journey...
(4) ELECTRIC MOTORS (A54757)
(4) ELECTRIC...
NEW Wolverine 72in Skid Steer Tiller (A59000)
NEW Wolverine 72in...
2016 INTERNATIONAL 4300 26FT BOX TRUCK (A56129)
2016 INTERNATIONAL...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A56435)
2018 John Deere...
