Using oxygen tank on its side
/ Using oxygen tank on its side #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
OK, I know its a major no no on Acet having it lay on its side, but what about Oxy? What about Propane? I assume on both the issue is liquid in the valve but I am really not the smartest when it comes to these issues.
/ Using oxygen tank on its side #2
I don't know about a propane tank. Rig welders lay their oxygen bottle almost flat all the time.
/ Using oxygen tank on its side #4
Propane depends on how the tank is constructed. Look at the tanks on a fork truck.
Oxygen is fine, it is a compressed gas not a liquid. But you need to have it secure in the extremely rare possibility of the valve being broke off. Then it becomes a projectile.
/ Using oxygen tank on its side #5
Forklift Propane tanks used on its side have a hole for a pin that locates the pickup in the liquid space. Therefore the tank only produces liquid not vapor
/ Using oxygen tank on its side #6
Many if not most propane fueled vehicles use liquid propane but it passes thru a vaporizer before going to the engine, so the tank is ok on its side. I ran a propane/gasoline fueled pickup truck for years and it fed from the liquid valve in the tank. It would run on vapor if the liquid ran out but had very little power. The vaporizer was heated by water from the radiator. A flip of a switch would put it back on gasoline but you needed to be moving at least 50 MPH to switch it over as it took several seconds for the engine to clear the propane and pick up the gasoline again.
/ Using oxygen tank on its side #7
+1 on securing that Oxygen tank. Years ago the welding truck delivery guy knocked a full one over off the back of the gas truck at work once without the safety cap screwed on. The valve broke off on something when it landed on the concrete and it took off like a missile. The tank punched through a block wall and went across the office floor by the secretary's desk and lodged in the concrete wall behind her; almost going through it too. Luckily no one was in it's way.
/ Using oxygen tank on its side #8
Yup. The carburetor on a propane powered forklift is heated and made to vaporize a liquid into a vapor.
/ Using oxygen tank on its side #9
I'm pretty sure I read on Welding Web a while back where MinnesotaDave changed fittings for fill and discharge on his forklift LPG tank so that he could use for cutting.
I think he worked for a propane company at the time so he knew what he was doing though.
Terry
/ Using oxygen tank on its side #10
Terry
Good memory - I added a fill valve on it so I could fill from the truck, but the vapor and liquid withdraw valves were both installed already from the factory (or I added the vapor one in the hole provided - can't remember).
The 80% blow-off valve for filling was already installed.
Interesting internals since the vapor has a loop of pipe that keeps it in the vapor when oriented correctly on it's side, or vertical.
The liquid tube goes to the bottom "corner" so it's in liquid vertical or horizontal (correctly oriented) as well.
Mine is the larger 43lb tanks and looks a lot like this.
(the liquid dip tube is like the second pic)
2007 Ford E350 (A55973)
2007 Ford E350...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
2020 MACK GRANITE (A60736)
2020 MACK GRANITE...
2014 Dodge Journey SUV (A59231)
2014 Dodge Journey...
Flatbed Truck (A55973)
