cub cadet rzt 42, model 17AE2ACG010 electrical problem
   / cub cadet rzt 42, model 17AE2ACG010 electrical problem #11
when you turn your ignition sw to ON, you should hear a "click" from the bottom of the carb where the afterfire solenoid is energizing to allow fuel into the carb's load circuit. ( that's the one you mentioned you broke the lead wire to ??) . If that solenoid is dead or stuck, your engine will not get enuff fuel to run well.
Check it's plunger for free movement while you have the carb off - if sticky, clean it until free.
Carb - soak overnite in liquid carb cleaner after disassembly. Using magnifying glass and small dia brass wire, probe EVERY orifice in each component, blowing same out first with rattlecan carb cleaner and then compressed air.Clean is the name of the game. Rebuild carb using a fresh rebuild kit - use ONLY new gaskets and valve needles/seats.
Good luck.
   / cub cadet rzt 42, model 17AE2ACG010 electrical problem #12
My neighbor had similar problem and finally called out a service tech. He replaced that stupid electrical think on the bottom but under warranty so I don't know the cost. The loose wire just sounded familiar, did it burn of from a malfunction?
   / cub cadet rzt 42, model 17AE2ACG010 electrical problem #13
Do you realize the post you are replying to is 16 months old?
Bob B.
2023 Vivid EV Electric Cart (A55853)
2023 Vivid EV...
SDLanch SDL30 (A53316)
New Kivel 3500 lb. Skidloader Forks (A50775)
New Kivel 3500 lb...
International 2100 Backhoe (NOT RUNNING) (A50775)
International 2100...
2012 HEIL CRUDE TRAILER (A55745)
2012 HEIL CRUDE...
(50) 12' 2"x6" Boards (A53316)
(50) 12' 2"x6"...
