DK 40 HST with FEL not responding to joystick
   / DK 40 HST with FEL not responding to joystick #11
Hey Green, Is this a new problem or has the loader been wonky from the day you got it?
Swap around the good working and the non working ports of the connectors and valve to eliminate the ports on the valve, or point the finger at the possibly defective QC connectors. or cylinders. build, buy, borrow or steal a 0 to 3000 hydraulic pressure gauge with the proper connectors to test the ports. After some of them test defective, then rebuild/replace the joystick valve assembly. BUT it is the QC connectors either not seated or possibly defective in some way..
Remember when you hear hoof-beats, think horses, not zebra's.. Could be Zebra's, but not as likely.:)
Well horses would be good but I am skeptical. I will do as you suggest, the reason I hesitate to break the connections is because of introducing grit into the system. It will be tomorrow at the earliest before I can test the removed and reseated connectors. Waiting on filters.
Thanks for your patience.
Hi Ritchey, this problem is only from the last hour of operation. Everything has been solid up until now. The system is tight with no leaks.
   / DK 40 HST with FEL not responding to joystick #14
My gosh James you are on the ball today!
   / DK 40 HST with FEL not responding to joystick #15
What were you doing last? In the woods?
   / DK 40 HST with FEL not responding to joystick #16
Yeah, now watch, with all my "good advice" it will wind up being the dang control valve.:eek:
   / DK 40 HST with FEL not responding to joystick #17
I don't think so myself.But you never know.
   / DK 40 HST with FEL not responding to joystick #18
I have the loader QC come apart on my DK45 and actually lost a o ring out of the female coupler and my NH TN 55 disconnects one of it's loader couplers on occasion while raking or bale etc, for no know reason. Don't worry about uncoupling and reconnecting that is what the QC's are made for, just wipe the male end clean and keep the plug in when not in use.
I just went to uncouple and reconnect all four of the QC and one of the QC was not seated. Just sitting there but looked connected.
Good call James and Murph. Thanks for your help, I should have known I was in the right place.
   / DK 40 HST with FEL not responding to joystick #20
Good deal, Welcome to the "pack". :thumbsup:
2016 KENWORTH W900 DAY CAB (A57880)
2016 KENWORTH W900...
Husqvarna 46in Riding Mower (A56859)
Husqvarna 46in...
Sterling 9500 (A55315)
Jack Daniels Miniature Decorative Truck (A55853)
Jack Daniels...
2015 Freightliner Bucket Truck (A55973)
2015 Freightliner...
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
