Can't post using iOS app
/ Can't post using iOS app #1
Bluest
Whitworth, Lancashire, UK
Yanmar F14D, DR Wheeled Trimmer
I've just tried to use the iOS app for the first time. I tried to start a thread but I can't type into any of the fields. The keyboard springs up but it appears be frozen. I have to force quit the app and start again. It's on an iPhone 4s if that's relevant.
/ Can't post using iOS app #2
I've had similar problems on my iPad mini retina.
/ Can't post using iOS app #3
Exact same issue on iOS 8 iPhone 6.
Just a frozen screen if you try to start a new thread.
/ Can't post using iOS app #4
HEY... ADMINS... YOU NEED TO FIX YOU APP OR GO TO A NEW ONE...... PPPPLLLLEEEEAAAASSSSEEEEEEE!
/ Can't post using iOS app #5
Guys, I use the TBN app daily with my iphone6. I used the 5 and 3gs before that all successfully. I can create, read and respond to posts. I can add photos from my phone. I don't think the app itself is broken so there must be some configuration issue with your phones or app. Have you managed to log in? You cannot post until you log in. Check that you are logged in in the settings.
/ Can't post using iOS app #6
My problem...Samsung S4....pictures most always show as a gray square. IF a picture does show, clicking on it to see a bigger version almost always shows a blank screen with some kind of blocks at the top in shades of gray.
I've gone from 100% pc user 3 years ago to about 90% users smartphone for browse of the internet including this forum....and this picture issue using android this forum is the ONLY real issue I have. It is NOT configuration of the phone since this is the ONLY place this is happening.
/ Can't post using iOS app #7
Today it is working again. They must have fixed something. I was definitely logged into the app but was unable to create new posts just as others have said... Frozen screen when you should type the subject. All is good now though.
/ Can't post using iOS app #8
I have same issue. Can't start new threads. Also can't post multiple pictures from Iphone 5.
2001 CAT 725 6x6 Water Wagon (A62679)
2001 CAT 725 6x6...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
New/Unused Wolverine Quick Attach Coupler (A65583)
New/Unused...
Landhonor 3-in-1 Welding Machine (A66408)
Landhonor 3-in-1...
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
TEST YOUR BID BUTTON! (A64277)
TEST YOUR BID...
