Front-End Loader will a 270 tl new holland loader fit a 1970 4000 ford
   / will a 270 tl new holland loader fit a 1970 4000 ford #1
mercomet
Fair Grove Mo.
4000 Ford
I'm wondering if a 270 tl NH loader will bolt up on my 4000 Ford
   / will a 270 tl new holland loader fit a 1970 4000 ford #2
It might be made to fit, but it will not "bolt up". No mount kit exists for that combination, and you will have to do extensive measuring to determine if the attempt is worth it to you. Not something I would want to attempt.
   / will a 270 tl new holland loader fit a 1970 4000 ford #3
:welcome:
To the forum from Northwest Alabama.
Thanks Rick. The guy that has it said it would bolt right up. But I was wondering.
Also hydrolic fluid leaks out of the rear break rod entrance in the rear housing. Not all the time but it does. Any clue what that is
   / will a 270 tl new holland loader fit a 1970 4000 ford #6
Brake rod seal needs to be replaced. Not a big deal if you have any mechanical expertise. Can be replaced from the outside.
Thanks again Rick. You seem pretty sharp about these things.
   / will a 270 tl new holland loader fit a 1970 4000 ford #8
mercomet, there is a post on KCMO craigslist of a man who puts these 270 loaders on tractors. If it will fit there a lot of these 270's for sale on tractor house.
That's the man I was talking to. Rick seems to think it would be a big job to make it fit. I think I'll just try to buy one that bolts up the way its supposed to.
   / will a 270 tl new holland loader fit a 1970 4000 ford #10
I'm actually adding this loader to my 4000 now. Rick is right its no where near a bolt up fit. And if you hired it done laybor would exceed the cost of a loader that would bolt up. Also how are you planning to supply your hyd? I'm still debating on adding a pump or power beyond? Something else to consider above the loader cost..
2011 4300M7 International (Pavo, GA) (A50123)
2011 4300M7...
JMR stump/trenching bucket (A53421)
JMR...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
2020 Nissan Rogue SUV (A55853)
2020 Nissan Rogue...
Honda EM3500S Generator (A55851)
Honda EM3500S...
